  • 1 month later...
Just need some coilovers... then mines not too bad :P Also waiting for my GTR spoiler to get painted and fitted.
More pics can be found here
Looks nice.. Your car is virtually the same as mine now - Same front bar, skirts, same coloured wheels.. Same mods and then me waiting on coils/springs too lol
Cheers Greg,
After a bit of research i learned it was a full top secret kit minus the front quarters with the vents. Its now got Tein Super Street Coilovers, Carbon Intake Pipe, Jim Wolf Popcharger and heatshield, Stainless Extractors and Johnny Spec Twin 2 1/2" mandrel bent zorst with highflow cats and x pipe.
Unfortunately Some lovely fu(k keyed it last week so its booked into the body shop to get the entire passenger side and front bar resprayed... Was so close to having a enough money to order some 20's for it and now this... iggnorant pricks... ah well... ill post some more pics tonight
hey thanks Greg
she is definatly starting to look good................now to make her go a bit faster........gonna be doing some engine work next year aiming to (hopefully) get close on 200 kW at the wheels
with no turbo, supercharger or nos :(
Heres a couple more, looking at some dress 20's for it but next mod will be a kazz 2 way.
Believe it or not were considering a VK56 swap for it... same reason we did blacky originally, the current engine/gearbox combo is worth alot of money here in aus, id import the titan engine and another vq 6 speed manual and adapt it... just researching atm... but its looking good ;)
Hehe yeah.. I ran a 14.32@98MPH with all the mods but with the stock airbox... Pretty sure its quicker with the stock airbox over the pod... But for the time being the pod stays as it gets rid of some of the horrid twin cam resonance it has, putting some extra resonators and expansion chambers in the exhaust over the weekend to hopefully fix that. Its plenty quick enough, but it would just be damn cool a V8, especially the VK56.
ill have to get some 560GT badges made up just to confuse people if and or when i do it :)
marios r33 is f**ken shhhmick! +10 votes for you
i love the white r33's even if there are alot of them around, my old stacked 33 was white my new one is grey....i like white better =/
where did you get your interior done? could you post some more pics of the interior? cheers
thanks man, at least i got a fan haha
ive changed the car a fair bit thou, lowered it more, added the rest of the kit etc, looking shmick
a mate in sydney dun it
im tryin to sell the interior now so hopeing sumone buys its
i will get sum shots up of the trim thou
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
