ooooh
5 stud conversion
me thinks s13 bouncy bits and s14a front hubs??
so close, i used s-13 HSD HR coilovers with s-13 hub carriers with 5stud conversion hubs from justjap on the front...
it's only after you buy all the bits that someone tells you you can use s-14 hubs...... :yes:
  • 1 month later...
Lol you thought that guy with the r32 was low..
I'll post some pics of my s13 in a few mins.
So low after clipping the road a couple times while driving through the national park the exhaust dislodged from the cat, only held on by 1 bolt! Sounded like a light plane and went like a truck. :D
YEAAAAAAHH!..
Nice find!..
Sizes?.. Offsets?.. Weight?..
Havent seen many of the 4 stud ones around!.. Nice work!
i took a photo of the sticker
17 x 8.5 +35 (for all four rims)
weight? an amazing ~7.5kg!!
yeah 4 studs are hard to come by, i heard from an unreputable source that only 200 (or was it 2000) sets were made. even then, this set is the 3rd set i've only seen in about 5 years.
Hey this is my NA 34.
Just waiting on a new engine to go in cos i cant handle the lack of power lol but yeh just thought id see what people think.
And i hope the pic works cos im not very good at all the posting stuff.
i love the paintwork. you coulda done better on the wheels though (more offset). they look tops but the car doesnt feel complete
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
