Before i got my GTR spoiler:
After i got the spoiler:
Keep an eye out, still many more mods to come =]
Although wont be able to post in the thread for much longer, turbo-charger coming soon =D
love it! subtle but obvious enough to pack the punch. Cara lookin back a few pages the shots are nice but you should get a someone to do a shoot of it with graffitti'd wall in the background. Be careful to pick the right wall though so your car doesnt fade away into the background.
I was fan of the black r34 4dr on page 35 and the white one on this page for sure!
thanks man, got the sides & rear from carmate :huh: ..Josh at JSAI supplies those front bars now (only guy in Aus selling em - however people have had a few problems with him)
update: changed my rims to Starcorp Impuls hehhe diiiiisshh>weight lol
post-47244-1250317369_thumb.jpgpost-47244-1250317496_thumb.jpg post-47244-1250317760_thumb.jpg
Edited by lankanboiiR34
thanks man, got the sides & rear from carmate :( ..Josh at JSAI supplies those front bars now (only guy in Aus selling em - however people have had a few problems with him)
That is one nice looking 34 you have there :P
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
