I went drifting again also :) This is at the 'Stadium Drift' Event in Moree, held by Raceline. I placed 3rd in the Level 2 class.
Grey NA 4drs FTW :D
Edited by -Jimmy-
Did a few little mods to my car..
Got a carbon fiber handbrake and gear surround
Did a brake upgrade and painted the calipers gold. Also matt blacked my wheels.. looks a Shyte load better then silver.
and I just like this pic a friend took cause its trippy..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
