I was thinking about painting the mags (powder coated) metallic black and leaving the outer lip polished aluminum, what do u guys reckon?
Edited by R34 -_-
Hey luke,
How much difference does a half cage make?
Does the chassis feel tighter?
Does it help much with going sideways?
Where are the mounting points on a 4door?
Is it very difficult for passengers to get in and out of now?
Did you have to chop much of the interior trim?
Edited by GTS4WD
Hey luke,
Hey mate,
Chassis feels alot stiffer with next to no body roll. When jaking the car up from the rear tow hook it raises evenly. I only do grip (4wd) but out on track steering is very responsive. I had to drill holes to mount it in. mounting points are on the rear wheel arches, right behind the drivers seat near the door and in the front on the floor. I just leave my back seat out, roof lining stays in, sunvisors come out.
Cheers Luke
Hey mate,
Cheers Luke
Thankjs for the reply,
So does the extra stiffness out weigh the added weight?
Ive removed sound deadening, A/C, heaps of shit behind the dash so i should still be below the factory weight.
Wanna get it on a weigh bridge and see how much it is. Later on will be fibre/cf doors, bonnet, boot etc but not for awhile.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
