  • 3 weeks later...
Not a skyline but here we go anyway.
At the Drags. Unfortunately for me, the clutch was slipping on takeoff so i couldnt launch it......2500rpm and slip out was my only option :(
Ran 15.017 @ 97.22MPH, my 60" was 2.348 so with my brass button clutch coming soon i'll run it again. Unigroup have said the car should run a 14.5 with that MPH if i get a good clutch and some good tyres :D.
Only mods are twin 2.5" Catbacks, Pod Filter & Underdrive Crank Pulley. Will be putting in a SAFC soon aswell as some Kumho Ku36's ;)
when i first got it
wheels and a catback
impul sides and rear (sorry about bad quality)
nothing too special but alot of work has been put into that paint!
my latest effort at detailing it :)
next steps will be new suspension set up, gt-t brake calipers, brake pads, and hopefully a new front bumper and bonnet, then followed with a high flow cat and MAYBE extractors although the cost of thats probably not worth it but i want to get the most I can out of this car without spending a fortune! may eventually get it tuned as well if thats worth it.
*edit* cannon has now been changed to an oval muffler - sounds a fair bit better :)
Edited by Jonno34
when i first got it
Considering a NIS-Tune myself......, drop the car soon, 18inch weels on standard R34 suspension is to high.
^ 147rwkw sounds great for a n/a! more than enough power for me if I could get there
and definitely, sits incredibly high with 18s and stock suspension, my shockies are leaking too so thats my excuse to fork out the cash for new suspension :)
I emailed the workshop who did this R33 about four months ago and they said you could pick up an extra 30kW from the Nistune ECU (which is actually a modified Z32 ECU I believe). And in regards to your car, she sure is high! I don't even know what my suspension is, it's higher at the back though that's for sure. Once I get my 18" TE37s, I'll work on my suspension. Lol.
I was just browsing through the n/a forums in regards to the Nistune on an n/a 34 .. not too sure if it fits :\
long way to go yet before i worry about that though! suspension/brakes to do first and that will leave me broke for awhile ..
*edit* 30kw from a ECU + tune seems a bit unreasonable, most of the figures say around 10 or so .. probably isnt too much for the money
Edited by Jonno34
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
