This is my mates R34 GT, rolling on Superlaps.
Its one of the best looking 34's around let alone the best looking N/A, in my opinion anyway.
  • 3 weeks later...
that car gives me a rock hard boner.
wheel specs?
loose the I'm a wanker sticker from the windshield and grab some jap wheels and it would be great.
also imho, the bonnet is a bit naff, given not much heat comes from a 25DE engine bay
I will be taking off the "I'm a wanker sticker" as you put it . so many ppl hate on it . . you would hate to see whats on the rear window then lol
Edited by joker's r34
whats on the rear window lol?
(hey man cant be any worse then mine, we got some mates together and got some small stick on vinyls made up and we all get around with them stuck to our cars rear windows, its fully fast and furrious team spec ;P)
You got the same bonnet add on as i got on mine
Worked RB26/30DE underneath that does get warm
What's under yours/ going under yours in future?
Hey dude is your bonnet cut in or just moulded on top ? . Looks done well tho I must say
I'll post a pic up tonight of my rear window and my "AWESOME" sticker
we should start a (who's got the worst sticker on there N/a page ^ ^)
LOL
Happy ? :)
LOL
Hahaa, dude thats not that bad. pretty witty lol :P.
weve got a small vinyl sticker that i designed then we each put TOP GUN nicknames with them, im not even kidding, we've got Maverick Iceman Wolfman Slyder and Jester atm LOL :P
(if you have an NA skyline you've gota have a sence of humor)
http://www.facebook.com/home.php#!/photo.php?fbid=10150281244601363&set=t.607876362&type=1&theater
(Thats a pic of the iceman one on a mates XR6t, hope the link works lol) *we're getting off topic, back to the NA 'lines
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
