My NA :P
Shots are a few weeks old so front bar and extractors are missing but this demonstrates well enough lol
(Image assistance credit goes to Tailor Made)
Haha thats fkin amazing, your cars got that chevy orange color as well =p Engine seems to fit nicely.
Edited by Deza3000
Thanks mate, it should be seeing some track time at willowbank in the coming months. Will post results, those photos are a few weeks old the car has the front back on it now extractors and wiring cleaned up.... Just tailshaft and the mafless tune and she'll fire into life :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
