Hi all,
Got an R32 GTST, installed some nice pioneer splits in the front (kevlar ones) a few years ago and some cheapie clarion speakers in the back and a 10" sub ported slightly incorrectly and has a very deep response. all hooked up to 4 channel kenwood amp.
Now the rear speakers are blown, i want to replace them, but on the cheap.
I'm also missing a lit of mid bass, the sub is gives deep bass ok, the splits gives mids to high trebs but seem to miss alot of the mid bass and midrange. its like most of the sound i hear is from the tweeters and the sub.
I never bothered dynamatting/or putting that rubber deflector thing flexorb on the back of the front splits)
Does this have a large effect?
Also i was looking at these for replacement rears. Just simple 6.5" "paper cone woofers" that'll hopefully recover some of the midrange i'm missing.
http://www.jaycar.com.au/productView.asp?I...mp;SUBCATID=396
Anyone had any experience with these? should i even bother with these?
Also as a note i'm not going for loudness, just hopefully more quality, half the stuff i listen to is jazz and cafe style music.
I have found a lot of the jaycar gear to be quite reasonable for the money, but in your system I would probably spend the money on sound deadening the front doors (a tin of underbody tar is cheap, but messy- found at autobarn etc, or propper matting - more $$ but easier) and forget about the rears.
A propper enclosure makes a big difference, even a good set of speakers will be rubbish if the enclosure is poor, and mixing and matching different speakers wont help.
If you do go for the tar option - I use it all the time, be careful, it sticks to everything and wont come off. When using it, mask off the area, and wear thick rubber gloves and tie garbage bags on your arms up to your arm pits! Its cheap and messy, but works really well - I dont bother with anything else and I have built my share of systems :D
Thanks for the reply, i'll go with sound deadening..
now.. anyone know where i can readily pick up some Dynamat stuff in Melbourne?
You could talk to Jaycar about sound deadening. They have plenty of materials;
http://jaycar.com.au/productView.asp?ID=AX...=&SUBCATID=
Never given it a try though, let us know how it goes ;)
Hi all,
I haven't heard the Jaycar speakers you noted but have just heard a set of Response 6.5" in the rear of a S15 driven only by a mid range Kenwood head unit and I was very impressed.
They are a bit dearer than the ones noted but my impression of Jaycar stuff has just gone way up.
See ling below.
response speakers
yeh will prolly go for the 2-way 6.5" jaycar speakers.. its $99 for the pair rather than individual, so definately a good buy.
(oh as a note the ones i was looking at were 8ohm home speakers rather than car ones.. and so are sold individual basis)
I've sound deadened the doors with 3 rolls of dynamat.. wasn't enough to fill the whole door inside skin and panel. but got to at least 3/4 of it.. so mainly did the area around the speakers.. added some focal plain chant foam bits too..
the outcome..
much heavier door.. prolly added 2-3kg's to each door.. and u can definately feel it.. when opening on an angle watch out.. u may forget the extra weight and wack your door against something..
The sound.. when i first heard it.. i'd say definately a more noticeable punch from fronts.
hrm.. i'm not sure if it was worth the ~$180.. however.
Edited by quink
I have Jaycar 6.5 inch Kevlar Splits up front and they are fantastic. I also have a 12 inch carbon fibre jaycar response sub that is absolutely awesome! Top stuff and really cheap too.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
