Hey all,
I am about to buy new coil packs and before parting with my hard earned cash would like any feedback from people who have gone though the process of identifing ignition issues on their rb25's
Ok this is the current situation.
mods = pod / full exhaust / fmic / upped boost (using turbo tech)
R33 gts25t series 1
Previously :-
running 12.5 psi on stock ecu , stock turbo, and slight correction with safc.. Used copper plugs bcp6re (copper .8mm heat range 6) and the car pulled all the way to redline with no worries, no R&R no missing coughing farting nothing.. ran sweet, no black smoke on boost or gear changes..
Current :-
On the weekend, replaced 20000 km old copper plugs with new iridium plugs (.8mm heat range 6) , removed safc and wound boost back to 8psi. get a little bit of missing and hesitation no under load..
please note : the safc was never 'tuned' only had -1 % correction from 2500 rpm to red line which effectively bought me under the r&r threshold and allowed smooth power delivery across the rev range @ 12.5psi.. Well thats what I was thinking at the time..
Considering when I had the coppers in everything was sweet and now the motor runs smooth but missing under load on 8psi, is it wise to just spend the money on the coil packs and be done with it? Or revert to coppers.. The rationale behind switching from copper to iridiums was to increase the service interval on the plugs.
What do others think? Coils or cheap ass plugs again?
Edited by turbs33
you will find a lot of cars getting up past 350 rwkws with the standard coils, mine included.
generally my rule of thumb is! if you have a problem? what was the last thing that i touched that was ascociated with the problem?
look at that first as its more then likely the reason for the issue.
there could be multiple issues with your car from the wiring where the safc was removed to plug gap, plug choice air leaks etc.
dont just fork out $$$$ for coils if yours were working perfectly before you touched it.
mine handle 24psi daily with no issues at all.
Yeah mine went over 350rwkw too.
I would have put coppers back in there. Increasing service intervals doesnt generally work.
Iridi's never last thier cost in terms of km's ive found. They are usually in need of replacement before their 100k
Did you gap the plugs yourself? You could have damaged the tip (they dont like being touched really)
I'd go back to coppers, the exact same plug you had before and see
Trident, I wound boost back as i was missing so figured id drop boost to try and aleviate the problem.
The iridiums i put in were gapped .8mm standard.. Cant remember the part number but its the one without the -11 on the end.
The coppers i pulled out looked really good for 20000k's actually looked like they could be re-gapped and last another 5-10k..
I will replace the irid's with the coppers i took out after checking the gaps and see if the car likes them better..
I spent some time down in the wiring loom ensure there were no shorts , exposed wires and the like when removing the safc... I am relatively confident the problem does not exist there. Though to my amazement there has been alot of wire hacking in there in the past, can see all the tape up wiring.. I will return there if coppers gapped right at 8psi cause me issues.
Thanks guys for the input, you have convinced me not to spend the moeny and to get off me ass and put the coppers back in...
unique1 lol read the post i said the ones without the -11.. meaning i got .8 mm plugs..
andhow problem solved.. f^cking cracked plug.. :) there ya have it.. pays to check everything properally as its going in..
Also i notice that the bcp6es are a taller plug then the bkr6eix <- is this not the correct iridium for rb25?
the above mention coppers seat into the coils so much better due to their height..
I am going to stick with my coppers for now 5x bkr6eix for sale 50 bucks plus postage. any takers????? oh they done 29 km's
Edited by turbs33
  rev210 said:
Standard coils are great when in working order. Leave them alone.
x2 500rwhp @ 1.8 bar on stock coils. The only reason people see a diference going to splitfires is because thier old coils were dirty/busted and the splits are new. I did the dremel the inside trick and they were like new.
dont go paying pounds sterling. go to your local auto parts store.
buy the coil pack for a 3.8 litre v6 holden commodore engine
1 meter of 8 gauge wire
3 meters of 16 gauge wire
one diode with the capabilty to with stand 12 volt 100 amp's (ask the guy at dick smith's)
6 spade connectors to plug into the holden commodore coil pack
6 1 meter long bosch ignition leads
6 Ngk spark plugs with a .8 ml gap
then go to your local auto electrician and tell em you want a wasted spark system, and need the car back by lunch time..... ;)
After my latest episode, it makes me wonder how many people actually need new coils or if the problem is something else..
wrong plug etc...
Can anyone comment on the iridium bkr6eix being the incorrrect plug for a series one r33? the top part of the plug just is not as long as the coppers i mentioned abaove and hence does nto seat as well into the actual coil...?
Anyhow I am sticking with the coppers.. Just curious.
Edited by turbs33
hey dude, i was going through the same problem! i purcashed a pack of iridiums! and my car was missing pass 4000RPM and was missing to redline... I had em on for about 4months and i got really angry and it took me that whole 4months through researching through the fourms and so i decided one day to go to Supercheap and buy these cheap spark copper plugs! i cant rememba which one it was.. but it totaled up to 24.90, they were pre gapped to .08mm and heat range was 6 i think? im not at home atm so yeh when im home i'l put up
Yeah there the coppers i had been using and am now using again..
bcp6es i think .. heat range 6 and gapped at .8mm and never miss a beat..
But F'it i just left the coil cover off and that saved 5 mins on a plug change for the future.. beside once ya do it a few times it takes like 30 mins max if ya dont piss arround :blink:
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
