ages ago i got a front bar from japan, they shipped it on a boat, but in the end it was a royal pain in the ass, as I had to pay for shipping, pay some Aus company for use of container, clear it through customs myself and then pick it up from the docks.
now, there is an exhaust I want but weight is 40kg.. so over EMS weight and expensive with EMS too... the guy said it can be shipped AIR or SEA.. now does anyone know how much it will cost me, and will I need to clear it through customs and all that crap, or will it be just like EMS, right to my door.
thanks for help!
dave
https://www.sau.com.au/forums/topic/21600-shipping-from-japan/
I bought my trust mx exhaust from takakaira, cost heaps of $ but no hassles through shipping via EMS right to my door. Try nengun or greenline, they'll probably ship your item includes all the required documents for customs procedure.
  • 1 year later...
Gee, this thread was more than 1 yr old!
Shipping via EMS is a killer particularly with heavy items, but with the advantage of tracking number so you'll know where your parcel if it got delayed.
Try SAL (Surface Air Lift) if it's not too big, it'll be much cheaper but there will be no tracking number and if it's missing, you're on your own.
wheels cost a fortune... i was looking at that... something like 225 ea EMS, or 150 ea SEA... damn expensive.
Dont you get parts send from japan to aus all the time with the parts you sell on here???
Is sea freight from japan to aus roughly 1 month delivery time?
Do you pay customs / import tax on big things like rims?
look at the age of the first post u tool
SAL is the way to go. All packages get sent to your door. However if customs decide to stop it for quarantine or it exceeds the threshhold value then you have to go out to Tulla and submit the formal customs lodgement etc. Big pain in the ass. If they don't then you're sweet. Basically the postal service of australia handle EMS, SAL or sea freight. so you have to do all the customs clearances yourself.
If you wanna avoid it go with DHL, UPS or FedEx (I reccomend UPS), they do all the customs clearance and stuff and then bill you for it later.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
