Gokarting Now Booked For Fri 8 Aug 8pm Gepps Cross $50 Pay Bunny By 31 July
I hear alot of flapping around but not alot of organising. Im sure Nick will get around to it soon, thread wouldnt have been created if nothing was to happen. Just hold your horses you flamin mongrels :(
Lol @ kel and krishy, so apologetic, its cute
  • Replies 398
Posted Images
hahaha my protector to the rescue :):kiss:
no harm done i know where you were coming from Krishy
so can we get this show on the road :)
krishy at least steve and i organise things who gives a F*&%ing shit if he "gets around" :)
WOW eze up there kells.....i am pretty sure that steve saw the funny side of it....
wow, maybe we should just have a little patience and let the man who started the thread/idea do the organising. If someone else goes and books a date and nick cant make it im sure he would be slightly pissed as it was his idea. Just give the man some time.
oh nick, hurry up bitch :P
amen brother.
waiting........................waiting.......................waiting
:) goes to the :mage: and asks can you eat pheobe the witch, and the dragon said "aarrrrr yes with pleasure" so off the :bunny: went with :) and had a happy :D
lol, wrong thread for that.
This gonna happen soon? Im looking forward to it!
im in to, i'll bring the banana skins and mushrooms, mario kart styles FTW
Well it depends on how many u had?
Dag, I didnt mean for you to eat the whole bag!
-D
  • 3 weeks later...
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
