Gokarting Now Booked For Fri 8 Aug 8pm Gepps Cross $50 Pay Bunny By 31 July
I HAVE BOOKED
Where: Kart Manis Gepps Cross
ADDRESS: 1 Port Wakefield RD Gepps cross
When: Friday the 8th August
TIME: 8:00pm Get there
8:30pm Race
What: 80 Lap Enduro Race
Price: $50.00 ea
Duration: 1 Hour 20 Min
I have booked the Team Enduro Race it requires a min of 16 people and a max 28
It's a 2 team race with 40 laps each
I need all money by the 31 july if not you dont go
thanx
THE LIST:
BUNNY
DSTROY
DAMO
JENKIES
  • Replies 398
Posted Images
im hoping we will be set up in A.S by then, so put me down!
will give you the money on sat kell
If your not finished ill come give you a hand Craigy, and vice versa i hope :D
If your not finished ill come give you a hand Craigy, and vice versa i hope :(
of course, your still part of SAU, even if you did ''dog'' us for another display....... :D
FRIDAY!!!! noooooooooooooooooooooo..... =(
i'll see what i can do about attending this one, but may have to miss it =( (you and your fridays....) =P
[weaksauce][/weaksauce]
will try and get there, depends what time i take my car over for the trade display (hoping its middle of the day)
i went there a while ago the dude there told me kart 11,5,3 are the fastest but not certain anymore just turn the white dial at the rear of the kart to make em go faster have fun all.
ahhh, damo....how are we going to get from auto salon, to gepps cross, with no car?
i might have to invite my mate, then he can pick us up after set up, race with us, then drop us home :(
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
