I am in the market looking for a turbo for my 500BHP ( more or less ) CA18DET project. I have been looking at Garrett´s GT3076R ballbearing turbo but I have learned there is a "fake" and a "real" GT3076R.
As far as I have heard, the difference between the two turbos is that the "real" 3076 has got anti-surge and different compressor/turbine wheels.
I am sure the "real" 3076 would be best for my engine but unfortunately I don´t have that kind of money right now. The "fake" 3076 is almost half price in Denmark but how would it do on a small engine like mine, compared to the "real" 3076???
Which turbo would you guys use on a project like mine???
If you have some ideas I can use for my project, things I might have overlooked or something I should do different I will be glad to hear about it.
I have rebuild my engine with the following specs:
Engine is balanced to 8500 rpm.
Apexi Power FC + Commander
Wiseco forged pistons ( 1 mm. Oversize ).
Pauter connecting rods.
Standard crankshaft ( Knife edged, regrinded, balanced and kryo treated ).
Standard head ( Reworked chambers, valve stems and three angle valve seats ).
Trust / Greddy 2mm. metal head gasket.
ARP head stud kit.
Mechanical lifters.
Jun lightweight flywheel.
Exedy paddle clutch kit.
Trust / Greddy timing belt.
New oilpump ( Nissan ).
Tomei camshafts ( In. & Ex. 260º - 10.25mm. )
Tomei Adjustable cam pulleys ( In. & Ex. ).
Tomei wide coil valve springs.
Turbonetics evolution wastegate.
Treadstone intercooler ( Core size: 550 * 200 * 90 mm. ).
Dump valve ( Aluminum. Adjustable. 51mm piston. )
K&N large Air filter.
Nissan Q45 throttle body.
300ZX Z32 Air Flow Meter.
Walbro fuel pump ( 255 L/min. ).
Sard adjustable fuelpressure regulator.
Sard 800cc fuel injectors.
4” stainless steel frontpipe ( Homemade ).
3” stainless steel exhaust pipe ( Homemade. No cat. ).
2.5 “ stainless steel intercooler pipes + silicone couplers.
Cusco race engine mounts.
Apex performance short shifter kit.
Brand new radiator ( Same size as OEM radiator but twice as thick ).
2 electrical fans.
Oilfilter relocation kit.
Innovate motorsports wideband sensor.
Datalogit logger ( for Apexi Power FC )
Cheers
Jesper
forget the fake one, as it could destroy your engine if it is a super fake one.
Why spend all the money and skimp on the main component?
Go and ask for a Garrett GT3037.
I had the 7 blade version of the GT3076 and it only made 240rwkw before it ran out of puff
Mafia:
Never said thanks for the map you sent me. It gave me a good view of how much you actually advanced the ignition. So THANKS. :)
But ehm... A garrett GT3037? isnt GT3037 a HKS item? :(
The turbo he is talking about is not a "super" fake... Its just the 7 blade version.
Edited by nissan200sx.dk
700382-5012 GT3076R 350-500Hp (2.0L-3.0L) 700177-5007 436157-23 YES 0.60 57.00 56 448420-2 54.98 84 Not Supplied N/A N/A YES N/A Not Supplied YES M14x1.5 Inverted Flare .438in-24UNS 2 Bolt M8x1.25 Purchase Turbine Housing & Actuator Seperately
I've emailed you a speadsheet with them all on it
Edited by The Mafia
actually. no.
HKS make a GT3037 Pro or GT3037 ProS
Garrett Make a vanilla GT3037.
The difference is the Compressor Trims. Garrett run a 56trim, HKS use a 52 trim
the current HKS 3037's are all 56 trim comps as far as i know.
contrary to the above comments the HKS 3037 is available in 3 trims 48, 52 and 56.
built a killer 300+ rwkw CA18 for a guy in sydney (same guy has his black 300awkw evo in current fast fours, acyually its his mums but we did the receipe :))
if i was you i would be looking at a genuine HKS GT3037 as the rear housing are far superior and on a small capacity engine will make quite a differrence (on skylines the differrence is measurable but the extra money vs gain is generally to small for many to warrant it) i do alot of SR20 engines and setups and can never match the Garrets resukts to the gen HKS items except in the real small GT-RS range.
i would look at the 56trim 0.73 rear 3037S part number 1401-RA127 (450+hp) if it were mine i would run the 0.61 housing (1401-RA126) and live with a little less top end (420-440hp) and heaps more mid.
the other option is to buy the garret version and fit the HKS housings which are about $400-500 US
turbo is a gcg "special" 3076r with tial rear housing and surge slotted cover, 260rwkw on 14psi full boost by 3500rpm on a 2litre.
i apologise but the info above is taken from another forum, I'm not personally sure on the exact specs but i saw the thing close up on the way back from QLD, we all stopped at Raleigh raceway for a quick thrash.... it is by far the best engineered car out there... bar none.
Thanks URAS, yes GCG supplied and fitted my Tial housing too. The beauty of the Tial housings are that the T28, T30 and T35 housings all have the same size footprint. So I can swap turbo's without requiring new manifolds, gates, dump pipes.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
