looking to buy this turbo as i once again blown another hiflowed turbo.
the power figure im looking for would be about 270-280 rwk.
im not a fan of huge boost and wouldnt want to go past the 16-17 psi mark. What combo would i need in terms of a/r, housings would i need to achieve this.
i have all the supporting mods also. car is a r33 gtst. internally standard also.
when does it make full boost also.
Im also looking into a gt3540 but is it over kill for what im chasing.
can i use factory dump also?
this is my setup so far
internally stock rb25det
pfc
z32afm
hiflowed turbo (now busted)
full 3in exhaust
blitz fmic
600cc injectors
tomei intank fuel pump
cushioned button exedy clutch
future mods
power goal :270rwk minimum
splitfire coil packs
gt3076r?
better bov and which one in plumback??? need advice
need some solid advice.
thanks in advance
https://www.sau.com.au/forums/topic/216391-looking-to-buy-a-gt3076r-turbo-iw/
  • Replies 66
Posted Images
Best off doing a search, as this has been covered quite extensively in a few threads, but for 280rwkw, i think the general consensus was that a .63 or .86 3071 offered better response without any major top end power difference, as your not maxing out the 76.
i tried searching but couldnt find what i was looking for.
reason why im looking at the 3076r is not to limit myself in future when i decide to go full rebuild.
just looking for a quick street car for now though have future ambitions for using the car for track
i'm getting a 3076r IW with 0.63 rear tuned at the moment (got similar mods to you), should be ready tuesday. power goal is also 270rwkw
fantastic mate. would love to see your results.
what boost level did your tuner say it would do your power goal at?
do u also have stock internals?
A few people on here have great results with the .63 3076(try the mafia), although most of them find that the exhaust backpressure caused by the .63 limits the power to less than the 76 front can make. IMO .63 3071 for 270-300rwkw or .86 3076 for 300-330rwkw, .86 3582 for 330+
reason why i want the 3076r is due to me wanting to run lower boost levels to achieve the power, and not limit myself.
plus ive read the 3076 dosent come on boost as hard. which is what id want.
just after the opinions of this particular turbo only.
i was going to get the real 3071r but was told by a few sources the 3076 would more comfortably make 270 and be more streetable. plus i opted for the .63 taking into account i wanted less lag and i wasn't chasing >300rwkw
how many are there?
AFAIK there are two different garret comp housings and six different ex housings. I would speak to mafia, as thats the same turbo he has. I believe he thought a .86 3071 would offer the same response with a lower level of detonation, and slightly lower peak power potential(he is making 314rwkw 18 psi), although if you are considering more power down the track, a .63 3076r can be easily upgraded with only an exhaust housing when need be.
Check this thread:
http://www.skylinesaustralia.com/forums/Ga...io-t207931.html
The on-road results for the 0.63 seem pretty good, but there may be some issues with boost control by the sounds of things. They certainly seem to give a big whack of early response, and depending on needs and preferences that may give more torque, earlier, than some people want. Definitely ask Mafia and BHDave what is their general view on this characteristic.
The consensus amongst those of us with a turbine A/R of 0.82 (or 0.87 HKS version) is of progressive, driveable response. Haven't heard a complaint yet. At 270kW it might be a technical difference between 3071 and 3076 rather than something that you can feel or measure, if response is the goal.
As always, it depends on the use of the vehicle, and skill/preference of the driver.
Edited by Dale FZ1
Just specify 2 things up front. You want the waste gate ported as large as possible and you want an actuator rated as close as possible to your expected minimum boost. Do not accept a softer actuator and expect to just wind preload in. You will compromise peak flow out of the waste gate and as it's performance is already marginal you will introduce boost creep issues.
I don't think a 3071 will do much more than a genuine 280rwkw, the compressor just doesn't have the balls. So yeah, the 3076 is the turbo to get if you want 270rwkw with the potential for low to mid 300s.
As far as streetabilty is concerned, the 3071 small compressor, big turbine and small turbine housing gives a very early boost threshold. You end up with a reasonably linear curve and avoid the rapid power increase at 3500-4000rpm you'd have with a bigger compressor and the same rear end. I'd say it's very streetable and perfect for the lazy driver (like me) provided you don't expect to crack the triple ton.
il get an oil pressure test done first then go from there. i actually think the reasons for my hiflows dying is due to modifying the stock bov. wayyy to much compressor surge even on light throttle. comp wheel blew outwards towards the afm...
for the time being im going to run a standard turbo so i can just get my car on the road and run 11 psi or so. well see how that one goes for now
Moving to a GT30 based turbo will be something that should make you smile each time you drive it.
The highflows weren't from Slide were they? There was a few reported failures that seemed related to quality control in assembly/manufacture, rather than anything done/not done on the owner's part after they were fitted.
Main point being, if you are going GT30, do it now rather than spending the time refitting a stocker.
im not used to anything big as this will be my first worthwhile upgrade.
im over hiflows.
i have to wait a couple months til i get a gt30 turbo. need the car on the road quickly. stock turbo is just temporary :)
we just finished putting on a gcg high flow on a mates r33, got it tuned @ maztech, pulled 263 rwkw @ 13.5 pounds spiked to 15psi we got the sheet
some high flows are still good! ive got a gcg on mine and waiting for a retune next week @ racepace.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
