Hey man
I have just installed about two months ago a 3076r. i got 271rwkw at 17psi
your 600cc injector might max out at 270rwkw man
you might need bigger injectors or a fuel pressure reg
i have 740cc injector and there at 80% cycle
My clutch had the dick at 270rwkw also
i just bought a Os giken twin plate too.
As for coils. Man you need them as then will miss fire hard
  • Replies 66
Posted Images
Hey man
Get your car checked.
I am making 274rwkw @ 15psi on a rb30det, using 550cc and my duty cycle only reaches 72% MAX.
Wow boys nice replies.....................
With those injectors is there a Fuel presusure reg involved..........
I am using 740cc but my fpr isnt really in use ............
My turned name is Dave formally know as Dyno Dave. been tuning for over 20yrs
i believe he has some experiance
Charlie, without trying to start a shit fight or start throwing insults around, please confirm your injector size (don't just tell me they are 740's, take the number 1 plug off and confirm the colour, i'm assuming they are nismo's), the fpr base pressure and the fuel pump and wiring being used. 740's should be capable of a lot more if the rest of the fuel system is up to scratch.
Don't start claiming dave is the greatest tuner ever and what he tells you is gospel. Your results are significantly different to other results so find out why. Do not accept what one guy tells you. Either the dyno is reading low (which i know bel's doesn't) or there is some other issue.
Book in a run with UAS, CRD, Unigroup, JEM, whoever and get a second opinion.
I don't want to labour on duty cycles either, so can you post up the sheet on the result here?
270kW @ ~17psi with a 3076 on an RB25 is fairly typical, and a good stout result.
I saw from one of your posts that you are running an external gate. What manifold is it all bolted to?
:cheers:
Well hell in that case you may as well go and buy some 1500cc injectors so your "experienced" tuner can make 340rwkw @ 79% duty cycle. :)
No one questioned the abilities of your tuner, they are saying that something else may be causing your injectors to run harder; but a good tuner would know that 740cc injectors are good for 400+rwkw, so he should be looking at why your setup requires such a high duty cycle.
I do have an adjustable fpr, but it's currently running std pressure. Once my new engine is run-in, i intend to run more boost and hopefully crack into the 300+rwkw range. It is at this time i plan to see if i could get away with adjusting the fpr; If not i could always buy yours for a very cheap price ;)
That is fair enough.. it is ok not shit fight is starting
I am not saying dave is the best tuner ever
but 20 years experience ..... he must know more than a bit dont you reckon
I have Nismo 740cc (red)
i also have a Sards Fuel reg
Walbro fuel pump
They are capable of doin more.... well except for the fuel pump
Im have a tial wastgate gate off the standard manifold
and i get 17psi at 3500rpm
Well hell in that case you may as well go and buy some 1500cc injectors so your "experienced" tuner can make 340rwkw @ 79% duty cycle. :P
I do have an adjustable fpr, but it's currently running std pressure. Once my new engine is run-in, i intend to run more boost and hopefully crack into the 300+rwkw range. It is at this time i plan to see if i could get away with adjusting the fpr; If not i could always buy yours for a very cheap price :)
Ill get my sheets on the comp and ill post them up asap....
Walbro fuel pump
Im willing to bet it is your pump and not your injectors i got my car tuned and it showed up around 80% duty cycle with 600cc injectors and was making only 245rwkw with 14psi...changed the pump, finished the tune and it showed 306 rwkw at 18psi and the duty cycle went back down to high 60s
On to the turbo I had a 3076r with a .82 IW rear made 306rwkw at 18psi and 260rwkw at 14psi it was quite responsive though i did have poncams to help, all up it was a nice linear turbo on the street not so much down low that it would wheel spin all over the place and not too laggy
hey mate,
Your 3076 was internally gated? Where did u source it from if u dont mind me asking?
:whistling:
hey mate,
:whistling:
I got my internally gated GT3076R through Slide on these forums.
Here is his new thread, i just happened to see: Slide's Garrett Turbos
hey mate,
:D
I got mine from this man here Elite Racing he was a few hundred dollars less than Slide at the time but i would get a prive from both.
What did you do about water and oil lines? also did it require a spacer plate?
How have you found the internal gate? No boost creep at the higher end? :thumbsup::D
Sorry for all the question!
Cheers mate
water and oil lines can be ordered from the above two guys it did require a small spacer, mine fitted on the manifold...but only by about 1mm so we thought it was best to space it out a little lol. I had a 14psi actuator I had no boost creep at all but if you had a lesser actuator I think you may strike the odd problem
Walbro fuel pump
why hasnt your experienced tuner told you that your running out of fuel! and recomended you change pumps?
as i suspected your running a walbro, which is a awesome pump for early stage 1 mods, but once past 250rwkws the walbro run's out of puff. change it soon if you like your bottom end.
Good pick-up
+1 to replace walbro pump.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
