  • Replies 46
Exedy 5 puk clutch - used for about 3000 kms... hardly worn, couldn't hold the 300rwkw... was fine at 270rwkw though!
$300 ono
still got it??
will pay now!
NPC rebuilt OS Giken TS2 twin plate clutch - Basically brand new except the splines are damaged on the friciton plate (riveted hub needs replacing on one of the plates) - push type $500 firm
where is npc at?
how many kays since rebuilt??
cheers
where is npc at?
cheers
NPC are in QLD.... although you don't need to get it repaired there. Although would be the cheapest option.
http://www.npcperformance.com.au/
1500km at most.... splines were damaged due to faulty input shaft... uploading some photos now..
npc rebuilt (jacobson spec plates)
os giken ts2bd. (not damperd anymore)
post-19586-1211797006_thumb.jpgpost-19586-1211796902_thumb.jpgpost-19586-1211796749_thumb.jpgpost-19586-1211796510_thumb.jpg
the "g box" one has the dammaged spline. pulled out due to motor rebuild. drove fine but upgrded to a r3c.
advan 048 semi slick race tyres.
20% worn. $385 a set. ($450 each new lol)
235-45-r17. medium/hard compound.
these have been used for 1 practice session at barbagallo.
porsche cup car slicks.
24-64-18.
aka 240-40-18.
these are almost completly new. again used for only one practice session. new tread depth is 3.1mm the LOWEST on these is 2.4mm.
so around 15% worn on average.
$600 a set.(4) ($550 each new)
6 available total. (2 on hold.)
also available is the rear. big ass gibson gtr size. (if you can fit 275's under the rear of you car these will fit.)
27-68-18.
aka 270-45-18.
also only about 15% worn.
350 a pair.
post-19586-1211800073_thumb.jpg post-19586-1211800894_thumb.jpg post-19586-1211801011_thumb.jpg
r32 gtr gearbox partly dissasembled.
smashed input shaft. suit rebuild or gearset upgrade.
r32gtr gearbox smashed 3rd. complete un-opened.. suit gearst upgrade or rebuild. still drives fine with no noises except no 3rd lol.
in the first post theres the 32GTR box and the 33GTS-4. but you've listed 2x 32GTR boxes?
is there a typo?
interested in the 33 box but not the price.
hey there
20% worn meaning theres 80% left still??
thanks
is there a typo?
They are one of each, but are the same thing. Only difference is the 33 bell housing is more strengthened than a 32 one. Both are push type, both suit a 32 GTR...
Pm offer, these boxes are Daves not mine so it isn't my call :down:
hey there
thanks
Yes, there is still 80% left :down:
ok, first post updated as of 6.6.08....
All irrelevant posts of mine have been deleted to clean the thread (ie sold items)
Cheers
Anna
If they are not picked up i will take them, need to be sent to Vic though
Hey Roy,
no dramas, il let you know if they don't get collected :)
Can work out freight etc then
mind shooting me a pm of the Rb26 please ? :( thanks! :D
no dramas, Il get Dave to send you one today. :rofl:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
