any suggestions? even if I set the threshold very low, eg 1, it will not show the dash light. I am running datalogit which shows that the pfc is reading more than 1 knock so the sensors and wiring to the motor are ok.
globe in the dash is OK but thats as far as my troubleshooting has got.
this is on an r32 gtr which i understand should flash the cat temp warning light.
https://www.sau.com.au/forums/topic/217143-pfc-not-showing-knock-light/
hmm hope not, I have a nismo dash and it doesnt have an engine check light.
Can someone confirm? I will change back to std dash if so
if that is the case you might not have to go ack to standard...you could probably wire up a seperate light kinda like a shift light or somthing..my r32 used to flash the check engine....but it was a GTST so that probably does not help you sorry ;)
yeah youd be able to wire up an independant light
get an auto sparkie to help
hey Bunta, almost 2yrs on the the turbo I got from you (that slide hiflowed) is still going strong dude ! ;)
my gtst doesn't have a check engine light. It flashes the exhaust temp light instead :/ As far as i knew no 32's had a separate engine/exhaust warning light, they share the same one.
When you get the stock ecu to give you the error codes it also flashes the exhaust temp light.
There's a single wire coming off the ecu for the check light anyway. Not a hard job to strip a section near the ecu and check for a switched earth (I assume earth as it seems to be the more common switch on the ecu) with a multi meter set for continuity and earthed on the other probe. You could start the car and listen for the annoying beeps if you have knock set to 1 as i'd expect it to have a nice little 5-10 point spike on start up.
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
