Eoi: Greddy, Cp, Arp, Garrett, Cometic, Tomei
Hi all,
I have a friend in the US who has just started a website selling performance parts for everything "RB"
www.rawbrokerage.com
Im gathering some interest for a group buy on some items he is selling.
Greddy Plenums
Garrett Turbochargers
CP Pistons
ARP Bolts
Cometic Gaskets
Tomei
The more i can order the cheaper it will be. I dont have prices at the moment as we are seeing how much interest we can get.
But if you go to the website all the parts on offer are very cheap,so only further reductions in prices can be had in the group buy.
CHEERS
  • Replies 40
If you are rebuilding an engine or doing some extensive engine mods,you need to look here first as i dont think you will find anything cheaper.
Poncams group buy sounds good.
However it is very important you know which type suits your car as i have a series 2 which was built in 97,the CAS change happend in Sep 97 and i ended up buying the wrong ones :D
All pre Sep 97 builds require the "series 1" type cams,even though you might have a series 2. Confusing i know.
RB25DET that is.
Ill get onto it and let you all know.
Thanks for all of your enquiries!
Turbocharger prices are now up: Garrett Turbochargers modified by PTB Precision Turbos (America) Modification is only to compressor.
GT28RS - $1496 Delivered
GT3071R - $1496 Delivered
GT3076R - $1545 Delivered
GT35R (GT3582RL) - $1612.50
(Let me know if you need any larger turbos) (These are all externally waste gated.Internals are $75 extra)
Also offering PTB Precision Turbo,Turbochargers.These are quick response journal bearing turbochargers.
SC50 450-460hp - $983 Delivered
SC60 580-600hp - $983 Delivered
and on up depending on what the power goals are.. ~$1210 for them. Delivered
These prices are at 3 or more so i will need 3 orders to get them at this price.These are in AU dollars and are excluding shipping.
I will get a shipping price on 3 turbochargers very soon.I will only place an order when i have 3 orders from you.
Look forward to hearing from you. :cheers:
how much for a garrett gt3076R with a .82 4bolt exhaust housing.. t3 flange, externally gated?
cheers :cheers:
Im pretty sure LTHLRB is reading my mind lol. .. And Sheng too i see lol
very very interested in the same turb if the price is indeed only $1452.50
also interested in greddy intake plenum to suit rb25det.
When is the group buy happening. Like when do we need to pay??
EDIT.....i must be blind. for sum reason thought u guys had written gt3582 haha. my bad peeps, ignore me lol
Edited by tm_r33
hey mate i was looking at the prices on his website.
the price he has on the gt28 on website is cheaper then the price he gave you.
for the gt3071R its the same as the website.
try n see if u can haggle better price then his normal pricing for multiple purchases.
Edited by tets
Those website prices are in US dollars mate.The prices i have posted are in AU dollars.
i know mate i used a currency converter
your price was
GT28RS - $1336
GT3071R - $1336
on site it is
GT28RS 1,131.12USD = 1,208.38 AUD
GT3071R - 1,250.99USD = 1,336.43 AUD
currency exchange rate used is 0.936067 so i might be a bit off.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
