Just letting everyone know that i sold my beloved R33 :)
I sold her to my mechanic for 9500 , she needed new sparks, coils , sunroof needed fixing , air con was broken and air bag/horn was f***ed so i think i did pretty good with that price lol ,
Its sad to finally let her go , she was a good little car who gave me many thrills and wow's.
I bought my dads car for replacment, Subaru Liberty GT , 2004 , i feel so old and mature now :rofl:
Ill try get some photos up tonight..
Cheers
Tim
https://www.sau.com.au/forums/topic/217212-sold-the-line/
I bought my dads car for replacment, Subaru Liberty GT , 2004 , i feel so old and mature now :/
Cheers
Tim
Mate, I sold my turbo R33 last month and soon to buy a Corolla... the petrol war made me surrender.
https://www.sau.com.au/forums/topic/217212-sold-the-line/#findComment-3835520
Wait till the petrol hits 2 dollars + for PULP (which is about 6 months away)... you will consider selling your Liberty for a Yaris :domokun:
lol , True.. i CAN catch a train to work if im desperate. then 1 tank will last me 3 weeks.
https://www.sau.com.au/forums/topic/217212-sold-the-line/#findComment-3835946
hahaha damn. yes the skylines running costs and insurance premiums has made me wonder if I shall keep it either.
Out of curiosity, whats the goin price of 98RON fuel in your vicinity when you last fueled up?
I filled up today and it was $1.56/L for BP ultimate. I'd say it's fairly good considering the price of regular unleaded down south.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/217212-sold-the-line/#findComment-3836677
Qld has it cheaper with petrol... we pay around 1.60 mark for PULP in Vic.
https://www.sau.com.au/forums/topic/217212-sold-the-line/#findComment-3837069
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
