Which Power FC will suit my S2 Neo RB25DET Stag and be a direct replacement for the stock ECU?
R32/33/34 GTR
R33 GTST
... and so on and so forth.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/217235-which-power-fc-will-suit-my-stagea/
R32/33/34 GTR
R33 GTST
Hey Reuben, if your Stagea is an auto, there is NO PowerFC suitable as a direct swap, because the PFC does not have any software/hardware to control the gearbox. I've heard (but cannot confirm) that some people have been using the PFC with a shift-kitted (and maybe manualised?) auto. Tangles might have a bit more information there.
If you've got a manual s2 Stagea, then the PFC to use is the R34 version, with the "secret squirrel tweak" for the traction control which is standard on the R34, but not found on the Stagea.
I figured as much. Thought the auto would be different ... next time I'll mention its an auto too :/
I know the PFC is a standalone ECU, but could you still retain the stock ECU to run the auto? Or is it wrong to share signals for that function?
Tangles ... info please :)
I figured as much. Thought the auto would be different ... next time I'll mention its an auto too :domokun:
Tangles ... info please :(
You probably could still retain the factory ECU, but the PFC is a full replacement unit, so it would take quite a bit of work to set up two computers to do that.
If I were you, I'd look at getting some piggy-back modules (such as the Apexi S-AFC and AVC-R, or their JayCar equivalents - there's plenty of info here about them already), or getting a piggyback computer like the GReddy E-Manage Ultimate(?) to control fuel and spark, leaving the standard ECU to control the box, etc,
RWD stageas have traction control well mine does anyway, i have an on/off button on the dash for it. i thought the secret squirel tweak was to stop the coils burning out. there was an article on an R34 auto with a shift kit running a haltech in an issue of fast fours or hot fours a little while. apparently with no problems???? i might try and find that issue and post it up.
no the tweak is to provide a traction control input for cars that don't have it - series 1 does not.
Also be careful, there are 3 different looms in s1 stageas and the pfc only works on 1 of them without modifications. I have another thread in here about this with same ECU part numbers
the issue is that the R34 powerfc pin 51 is for the R34 traction control. when there is no signal it throws an engine check light. the "secret squirrel" tweak is to send approx 3.6v (or whatever it is) to the powerfc thus turning off the check light.
on a S2 stagea with traction control it will probably just bolt in and work.
Thanks for the info ... I think I'll go the SAFC route then :bunny:
Shopping for one now! I wanna wind up the boost on the Stag :)
IF you do the Power-FC R34 GTT mod, you WILL need a) MV Auto shift kit for auto changes, to minimise gearbox damage thru lack of ignition retard on gear changes, eventually the gearbox will blow tho., b) you'll need luck as Duncan suggested, 3 different looms. S2 may plug and play with the secret squirrel trick, but its a risk.
Mine all worked, but I decided NOT to go ahead as I cant afford a gearbox rebuild. I sold the p-fc for what I got it for.
Currently dealing with Toshi for a ecu remap, my particular Stagea S1 ecu needs a small ecu - to - large ecu adapter plate soldered in, plus the ecu chip. looks to be around $650-$700 but unsure as at the moment.
Hope to have this sorted out in the next month, so will keep you updated. Chatting with Toshi every second day, so give me/Toshi a month or so and I'll report back in.
Once i get the ecu remap (wont be prefect as we are in different states, it'll be a guestimate), I'll have it soldered in and my car tuned with the SAFc/SITC still (fit hks actuator for 14psi stock boost) and let you know how it goes. he can remap for z32 afm, 040 bosch, highflow turbo like 2530 or 2540, 14psi, and use the safc/sitc for adjustments afterwards at your local tuner.
Rub's, Id suggest a SAFC Neo, an SITC if you can find one, a good 040 Bosch pump, a Z32 afm, and Nismo adj.FPR
tune all at one for a 180awkw tune
ppl will say the Nismo FPR is all bad, but they arent correct IMO. it helps when tuning a safc.
I won't go the PFC route now. But will it still pay to get an auto shift kit ... and what exactly does it do? Even with the shift kit it will still blow? I won't be lead footing it everywhere, 95% of the time putting around.
Thanks for the recipe :) I'm going that way with things then.
Wouldn't any fuel pressure reg do the trick? What about a rising rate FPR?
rising rate FPR's such as Sard are harder to tune the safc.
(according to SK)
with the nismo adjustable fpr you can bump up fuel pressure by say 2psi, and that way takes a little load off the injectors duty cycle
easier to tune the nismo fpr with safc then the sard from all Ive heard/read.
the shift kit will maximise the length of the gearbox life, should extend the life, will get quicker shifts, minimises the time the ecu retards the ignition on changes, definately a AAA+ modification to do. install shift kit and auto service at MV Autos is around $400
ok so at a guess, with my S2 which is an RSV RWD only with traction control i should be able to plug in a R34 pfc and just be able to drive my car to a tunning shop. it is an auto but i dont really care when the box goes as it will get me off my ass to put a manual one in. i only have a filter and an exhaust so far but more mods are planned. anything else i should know? does the pfc have the capability to upgrade the AFM to Z32 etc.
yes, powerfc has a menu to change AFM's.
it should bolt in like on any S2 and runt he car but yours should/may/might not need any other modification as i would guess the loom will be identical with traction control to the R34 GT-t so no engine check light (after you switch off the boost control kit on the powerfc menu).
Edited by wolverine
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
