PINGPINGPINGPINGs ~!!!
lol how can you question an official statement from nissan ? fair enough its not gospel but they have a lot to lose from lying lol. I'm sure they wouldnt want to give anybody anything to say bad about the GTR by lying
I dunno, I'll cop a lot of flack over this but 7:29 sounds a little too fast to be realistic. Remember the R33 breaking the 8 minute mark and then no one else being able to match the time? I just can't see the the R35 doing the 'ring that fast.
***PUTS ON FLAME SHIELD***
From what I understand the track conditions were improved compared to the 7'38" run the last time they were testing at the track.
Apparently, Mizuno is also engaged in continuous quality improvement on this car, re: performance attributes. This is definitely a good thing.
All further JDM and all US spec GT-Rs are getting different motor mounts with different bushings; I expect polyurethane leading to the 'claim' of harder engine mounts. There is also a harder transaxle bushing. The statement reads that these "small tweaks ...... stop the mechancial parts from moving under extreme cornering. It's detail like this that enabled the new 7 min 29sec... (Mizuno)". Also: "The new mounts make the car feel more together in extreme circumstances,' he said. 'We've also changed the spring rates front and rear – it's a minute change, they're just 0.1kg/sq mm stiffer. But it means the movement of the suspension and powertrain are more perfectly tuned."
So it looks like they have made some small adjustments to handling characteristics; and they don't look very expensive either. I am sure the original JDMs can probably be retrofitted / adjsuted with these pieces pretty easily.
thats a terrific effort, cant believe it, i was bragging to guys about the 7:38... The v-spec is gonna be wicked!
There probably will be a few bling pieces associated with Spec V, but...
The weight reduction is primarily through greater use of carbon fiber panels and light-weight race seats. These can likely be purchased after-market from Nissan or other. If people are going to autocross or track the car, then they will likely start pulling interior pieces out anyways, place a 5 or 6 point cage, and use race-spec seats anyways.
The engine tweaks can easily be done through the ECU. Cobb looks like there mapping method will be ideal for doing ECU modifications and keeping the Nissan maintenance coverage because the ECU can be flashed back to OEM (purportedly). It looks like the OEM transmission should be able to handle 600 ft/lb TQ pretty easily with little or no modification to the engine, just a tune.
If your racing the GT-R, your going to be replacing the clutches and a differential from time to time anyways. And lots of tiresbiggrin.gif
Carbon-ceramics are really only needed for race applications or if you are hot-lapping at the dragstrip. And who does that!!??*&! rolleyes.gif Although honestly, I have seen two after-market vendors are offering the same or similar brake pads (i.e. carbon ceramics) for significantly less than OEM.
I'd rather get the base model and make the journey myself. Hell, you can adjust boost to 1 bar (14.5 psi), do nominal weight reduction (e.g. get rid of the complimentary tools under the mat, lose the weight of 11 speakers), and swap some bushings and easily run high 10second 1/4 mile times.
aslong as they use the same start finnish line as lemans used to I will call it a mark... start finnish on the whip end of the straight after the first 'corner' isnt fair.
I'm confused mate, what do you mean "same start finish line as Le Mans"? It's a different circuit?
Phoenix, i assume you've popped over from NAGTROC?
looks like you've got some good solid info there, where bouts did you come across it all?
Not from NAGTROC.
Yes, I have done some research. I enjoy the journey of building very fast street-legal cars, but I really have just looked at all the vendors in Japan and seen what they have posted over the past year. I have seen a ceiling on the clutch packs. I am not entirely clear on what the engine can handle at the limits, but 600 - 615 ft/lb TQ at the crank is probably all I will need to accomplish my goals. I want the car to have some longevity too.
I prefer science over guessing. I plan on making this car run a 10.8 - 10.9 second 1/4 mile on street tires, maybe some sticky R compound BFG drag radials, if needed.
This is a quote from a post I made in the British forum.
This is theory. I used very few data points and 3 variables. I considered atmospheric pressure a constant, if you will, because I don't have enough dyno variable sets to incorporate into an equation. [please explain how to use 1.01 in this formula...multiply or dividethumbsup.gif ) This is a RATIO / PROPORTION grid with a couple conversions. I had 2 data points with which to compare with the factory numbers. Not much to go on. When you consider that different types of dynos (dynapack / mustang & dynojet) are being used at different elevations, yeah sure, it's not perfect by any stretch of the imagination. Plus, people use different octane fuels and measure crank vs. wheel with the other confounding factor of what to use for drivetrain loss (15 - 25%). One other thing, Nissan obviously, did not provide the ideal baseline to work from, because most consumer cars are showing around 435 HP to the wheels. Even with a conservative 'drive-train' loss of 15%, your over 500 HP to the crank.
Additionally, the 'load-type' dyno (mustang / dynapack) requires accurate on-road aerodynamics and friction inputs and the 'inertia type' (dynojet) does not. I think the 'load-type' dynos are GAY, sorry, my personal opinion. I much prefer the dynojet for higher HP applications. Most tuners use the dynapack for comparing baseline (prior to modification) numbers to engine mod; it is fine for looking at change. Dyno jet will give a much closer real-world number.
In terms of the theoretical number projections, this is what I posted originally:
Boost TQ (to the crank)
(bar / psi) lb - ft
0.7 / 10.2 433
0.9 / 13 551
1 / 14.5 618.6
Motor Trend (K+N engineering)
Wheel 430.6 - 435.8 HP, 425.3 - 439.1 lb/ft (range of results)
Projected Crank @ 15% drivetrain loss 506.5 HP / 500.4 TQ
Motor Authority (Dynapack)
475 HP / 428 lb/ft TQ to hub
projected crank 550 HP, 495 lb/ft TQ
Autoblog (Mustang and Dynagay)
406 HP / 414 TQ (Mustang)
452 HP / 448 TQ (Dynapack)
BEST CAR Magazine (JDM [consumer])(Dynapack)
485.665 HP / 428/1 lb/ft TQ (hub)
BP car (running 95-96 US octane rating)
457.7 HP / 444 lb/ft TQ (wheel)
520.5 HP (projected crank)
JSpec Connect (Dynapack)
460 HP, 456 lb/ft (hub)
I believe there is a general consensus that the power of the engine has been under-reported for whatever reason. The numbers given by the factory are probably more accurate (with a proportion given to drivetrain loss) as being wheel horsepower rather than crank horsepower. That is why the numbers seem skewed. Give me better data points, I'll give you better projections.
Conclusions: I don't think it is unrealistic at all for the stock components to give between 550 - 600 ft/lb of TQ (to the wheels) as you approach the drivetrain limits (as given by MCR and Endless) of ~ 14 - 16 psi on the turbo. Heat and efficiency limits considered. And of course, they probably beat the piss out of the car as well.
The timing method is standardised by Sport Auto magazine and has become the defacto standard for Nurburgring timing across the board and has been adopted by almost all manufacturers.
The start/finish line is no longer used for timing because it is dangerous. The Nurburgring is a public road and cars are constantly entering the track from that area. If you're going all out on a flying lap you're likely to crash into someone at that point.
exactly
regardless of where the 'proper' start/finish point is, the time Nissan quotes is using beginning and end points consistent with all recent times recorded for other supercars
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
