I have been busy on the skyline today and I'm after some info on BOV's,
I know some skyline's idle best with a recirc and some seem to be ok with a traditional BOV?
I have lost the original location for the factory Recirc and I'm after a bov that stands a chance of idling ok,
this is why the factory bov is no longer an option :cheers:
any help would be cool before I buy one
cheers
Matt
Edited by buffy33
https://www.sau.com.au/forums/topic/217601-bovs/
biggest problem most of us have with the bov is that they can stall your car at low revs. that goes for manuels and autos. thou it is easy to start up again.
but as long as you are prepared for it then you shouldnt have a problem.
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3840997
Why is the factory bov no longer an option?
All you need to do is make a flange ,mount that to the intercoller pipe, bolt the stock bov back on and then fabricate up a plumback/recirc pipe that goes from the bov back to the stock intake pipe, you can make it from anything really, any a peice of hose the correct diameter will work fine to, i done this on my old r32 when i was using a R.I.P.S plenum and it worked perfect.
But if you want to have stalling issues, go ahead and buy a different bov :cheers:
Edited by nizmo_freek
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3841137
yeah i gotta admit when i had my stock ecu and was running a hks ssq bov i never had idle issues
now using after market ecu and a greddy type s and it still works fine.
but lookin at plumbin it back one day as im over the squeel it makes ha ha
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3841191
as above i run a stock ecu and a hks ssq and i don't have stalling issues either.. and i am going the route of the greddy plenumn and keeping the ssq. good luckl. if you want the factory bov then do as nizmo freak suggested. cheers hame.
https://www.sau.com.au/forums/topic/217601-bovs/#findComment-3841201
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
