Hi Guys, Ive got basicly a stock R34 GTT.
The wife has said I can spend a few $$ on it :D :D
I want to warm it up a bit.
Budget is somewhere between $3000 and $5000.
Cant be too loud or Droney afterwards, its a car for daily use.
Whats the recommendations for the best bang for the buck?
I was thinking along the lines of
Pod Filter
Bleed Valve
Exhaust
Intercooler
Is that a reasonable start?
Any recommendations on brands / things to avoid?
Whats the Turbosmart E Boost like? Someone recommended one to me. Better getting this than a mechanical bleed valve?
Any ideas what increase in performance I would be looking at?
Lastly, wheres a place that does a good job at a reasonable price?
I bought it from Unique Autosports and Im quite happy to go back there. Anyone have good or bad experiences from them?
thats a start,
1st things i done
hks pod filter
bleed valve- boost up to 12psi
3'' exhaust,3''high flow cat, 3.5'' cat back
yet to get cooler but its in the process of being made.
saving up for apexi avcr- elec. boost controller
performance gain would be noticible with a good dyno tune,
UAS is where i get alot of my parts from and find them very good.
with just pod,zorst, and boost up i hit 146kw@wheels..
hope that helps..
cheers...
www.freewebs.com/2BNVS_r33
get a full exhaust and dont buy a bleed valve get an electric one instead. you can get fairly cheap second hand items such as the profec b. if your not looking for big hp you dont need the front mount intercooler. air filters also dont do that much. spend the rest of the money on some good suspension and a power fc. :(
I dynoed my car with a K&N panel filter and got 176kw@6007rpm with 1304Nm @4713rpm.
I fitted a 2 3/4 in stainless cat back exhaust and had the cat removed(because we can in NZ:p ) and then redynoed it and got 195kw@6660rpm and 1398Nm @4655rpm
This was on a dynapack pro V5 hub dynamometer.
All figures are at the wheel hubs.
You seem to on the right track, apart from the bleed valve. Forget about that and get an electronic boost controller. But a SAFC might be a good idea as well, to keep it from leaning out at higher boost.
Glenn
19kw just from removing the cat?
I didnt think they were that restrictive.
Im assuming that was the factory one you removed?
I removed the cat and fitted a 2 3/4in kakimoto stainless cat back exhaust. That gained me 19rwkw.
A SAFC is a super air flow controller, it enables you to controll the air/fuel mixtures by tricking the computer some how. I'm not really up to play with them, but have heard a few success stories from people fitting them.
Glenn
i'd go:
full aftermarket exhaust (one with centre muffler aswell as rear, since you dont want it too loud)
electronic boost control + apexi safcII, or can go for a more serious aftermarket ecu. try get these ones installed at the same time so you don't have to tune it more than once (save $).
Turbosmart E Boost is probably good, but you can also get jap brand EBC (electronic boost controllers) for a similar price. its up to you really.
instead of getting the safcII why not spend a little more for a greddy E manage. You can even find second hand power fc's for a little more than a thousand that will save you from spending money on the safc now when you will probably uprgrade to a a programmable computer in the future anyway.
GTS4 - are your kw readings to the wheels or to the fly wheel?
Check out this months issue of "Speed" the magazine. It has a RB25DET tune guide. It's worth a little look. Also got info on the V35 GT-R as well. Personaly I am adding a R34 FMC, Apexi Power FC with hand controler, air pod and exhaust to mine. Should go well I reckon. You'll get plenty of power before you even think on engine internals :P Just remeber they love to breath and the standard ECU's are full of holes.
the R34 intercooler is plenty big enough for the stock turbo.
It's thicker than the R33 cooler. If any of you R34 guys want to palm off your old stock intercooler let me know and I'll ping you $150 for it.
Get a light flywheel (and clutch while your at it).
Do the exhaust, all the way. Thermal wrap the dump & front pipe.
Diff cradle kit
Panel filter.
Boost controller.
For starters.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
