eh anyway after alot of screwing around i'm putting my belt back on my car.. now the only problem i have is lining it all up.
I've attached a few pictures showing the gears lining up with the backing/key hole.. i just want someone to verify that that's where u line these little nubs up at.
The engine is at TDC
Also on the cover for my exhaust cam gear (vac holder thingo) theres a white mark, which lines up with the mark on the exhaust gear.. which i'm assuming is all good.
Other question i have is where do u line the marks on the timing belt up with? do they line up with the white marks on the backing plate behind the gears(and the slot on the bottom one) or somewhere else? (i cant use the ones i marked on the timing belt because i'm wondering if it may have skipped a gear)
Also my exhaust cam seems to be a tiny bit more advanced than the other one.. they're normally exactly opposed right? i can twist it back a tooth by hand
Edited by GTAAAH
https://www.sau.com.au/forums/topic/218038-is-this-right-timing-belt/
looks all good to me , Make sure your tension is correct, i usally roll it over a few times then re check it, usally thae marks on the belt can be matched to the marks on the gears to make it easyier but they dont always line up, so use the marks on the motor.
hmm so to line it up without markings would i just make sure the idler side is real tight and then tighten the tensioner side so it's tight as well, or is it still possible it can be a tooth out on the idler side and i'll need a new belt? (this one is only a few thousand k's odl)
Edited by GTAAAH
OK that's all done but 1 other question i have.. does the engine need to be set to TDC when your putting the CAS on? i marked it and (altho the markings have faded) think it's real close to where it was.. but i'm just wondering if the positioning of the engine will make a difference? Also this thing you can adjust left and right to retard/advance timing right?
ty
ah yeh i have the half moon key slotted in ok, just wasn't sure, what your saying makes sense because obviously i didn't stop the engine at tdc hehe, bit of a brain fart there.. car will be all back and going tomorrow hopefully after hogging the garage for 4 months hehe
and the belt was changed as part of my buying deal, just before i bought the car and hasn't more than 2000km's on it, it looks fine so i see no need in replacing it
Edited by GTAAAH
ugh re-using timming belt's
stdish rb26 rebuild $4000 +++
gate's belt $120
i know which one i'd choose, who's to say you have got the belt going the opposite way to which it was worn...
STD belt from nissan cost me about $95
peanuts really :D
k it's all back together and car seems to run fine.. bit of a ticking sound i can hear from outside car or bouncing off walls.. i havnt had this thing on in ages but think that was there before hand.. how noisy are the injectors in these things? i'm thinking it's that.. anyways hopefully i'll drop by a mech tomorrow and get them to take a quick look, then it's clutch replacement time
thx for the help guys (in the other thread too)
The injectors are quite noisy, as are the solid lifters even when shimmed to factory tolerance. You can isolate the noises by giving the engine a race while listening. You will notice the injectors cut out on engine decelleration. If the loudest noise goes away in this situation then its the injectors :domokun: Another option is to use a proper stethescope or just a screwdriver on the suspect and the other end pressed on your ear.
By the way engine oil wont change lifter noise in a Rb26, as mentioned they are a solid lifter arrangement and do not require hydraulic pressure to operate. If they are noisey the only way to quieten them is to re-shim.
Hope this helps,
Deren
Ah thanks godzilla, the noise stays constant through deceleration (i didn't think it would totally cut the injectors on backoff) so i guess it must be the lifters that are the problem.. which isn't really a problem after all. thx for the help
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
