yay or nah
31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 131
Posted Images
And sadly I wont be able to make it to the drive in on fri ;| Gonna be working
Dagnamit
-D
damn ben(dohmar) was lookin forward to finally meetin ya! well depending on what time you finish there might still be a few of us out and about after. i know dan and myself would be keen to have a suss of that R of yours.
sam i know your new to the forum but try keep the illicit talk to a minimum and as a general passing joke. the mods may come down hard about it. :D
sold my 18"s last night so i will definatly be coming YAY. to the experts how much does it cost for a car to get into the drive in??
also got 14"s with vl hubcaps so looks like the vlt is back to ILUCV 1 Styles! YEA :P
:cheers:
$20 dolla bill yall im sure ive written that in here ya slacker. remember 6.45pm door opens ill be down there like 6.15ish hopefully try to get there sooner than later more likely to get good spots that way.
drive in finally messaged me said no group discounts and a whole lot of nothing for the amount of time it took them to message me.
Edited by Inline 6
chronicles of nanana is on after $20 is 1 movie keep in mind that 1 movie go's for over 2 hours and the other movie is a chick flick so i vote we blow that joint after speed.
o and thought id throw in a disclaimer
no hero's please keep it respectable in n out the drive in drive safely etc.
if the long arm of the law dont reach the back of my hand will :D and all shall be good fun n games
Edited by Inline 6
Hah. I'll be in Olympic Dam. Dont particularly fancy an 800km drive to Adelaide either ;P
-D
now whos unsociable dohmar :cheers: corrected no 1 will eva know
u gonna hit us with the 800km stare i heard :D take that
in response to below
me fail english thats umpossible
Edited by Inline 6
yeah i think we gonna have to go with it.
too late to cancel for the dirty south ppl.
im like 10min away from the place and its stopped raining now and while it dosnt look fantastic in the cloud department it looks like it will only be lite shower if at all. thats weatherman dan reporting to you live at the scene.
see you down there
will prob be parked 1 row behind the big projector light box thingy
dammit my car dosnt know what rain is its not gona like me anymore :)
Edited by Inline 6
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
