  • Replies 895
If the price is about $2k i wouldnt hold too many in stock as the benefits for the average skyline owner wont justify the price increase over pfc
again...this ECU is not suited to everyone....but think about this...
how many people spend $800+ on camshaft upgrades that have a minimal effect on performance...a lot!
wait until we do some back to back testing and publish some results...i think they will have a place in the aussie skyline performance market.
Feature list sounds suspiciously like a great aussie ecu I know, price too.
If it is the same ecu, I've seen nothing but good results with these, but as always its the tuner that makes the most of it(or not) in the end.
Edited by infamous_t
think about it...sell Power FC, AFM's and boost controller and upgrade costs next to nothing
well.. apart from the new intake pipes and re-tune, yeh.
I guess for those looking at MOTEC level of capabilities, it's a bargain.
for the masses of 12 second 250rwkw skyrines, it's not worth the extra dollars over a PFC.
when i think about it...
PFC $1300
Gizzmo Launch Controll $400 (second hand its 700 new)
Q45 AFM $180
Boost Controll Kit $350
I i will have $200 left over from selling all my stuff and buying this ECU.
ANother Thought...High and Low Impedence Injectors?
This Is Sounding Very Tempting...Although I have to get my car driving again before id think about this....Was going to Go an E11v2.
Waiting to how many see in/out puts this one has as I wanna run water Injection, thermos etc
Would be awsome to have water inj triggered by intake temp.
injectors can be selected from a table by part no. (denso ********) or brand (Blitz 1000cc) very easy...high and low imped.
water inj. triggered by intake temp. not a drama...switching on and off thermo's...just as easy
Edited by DiRTgarage
The following info might answer a few questions and clear a few things up for people.....
The V44 standalone has 4 injector and 4 ignition outputs. The plug-in ECU based on the V44 have six injector and six ignition outputs. The V88 model has 8 injector and 8 ignition outputs. Also it has knock control and DBW throttle control. Both ECU have motorsport features like antilag, WOT shift, launch control.
These ECU use a 32 bit microcontroller running at 42Mhz. This processor is designed for engine control and has the power and speed to work with crank and cam trigger signals in real time. It does not use the time based system like the Autronic. The result is far more stable ignition and injector control. On engines with multitooth crank triggers the ECU reads and uses every signal for maximum resolution.
Some of the features are,
Missing tooth engines can run wasted spark without a sync signal.
User can set reluctor input signal threshold. (this lets you tune out any interference)
Variable cam control for up to four cams. (V88 only)
Outputs can be controlled by GPC tables or PID with feedback.
ECU case is extruded with water proof connectors. Case is small and not box shaped (looks very good).
V44 has one connector and the V88 has two connectors.
Idle control is very very good and very easy to setup.
No popping in the exhaust on overrun with smooth transition in and out of over run
Fixed duty boost control.
Different boost in each gear.
Dual fuel and Ignition tables that can be externally switched.
Up to 12 cylinder multi coil engine support
DBW throttle control (V88)
QuickTune (Autotune) feature on both V44 and V88.
Inputs and Outputs:
V44 injector = 4
V44 ignition = 4
V44 analog inputs = 3/4*
V44 temp inputs = 2
V44 digital inputs = 3/4*
V44 AUX outputs =8
V44 Connector pin number = 34 (one connecter)
*one Digital input shares the same pin as one analogue input
V88 injector = 8
V88 ignition = 8
V88 analog inputs = 11
V88 temp inputs = 4
V88 digital inputs = 10
V88 AUX outputs = 10
V88 Knock input = 2
V88 Connectors pin number = 2 x 34 (two connecter)
V88 has:
- E-Throttle (drive by wire throttle)
- Peak & Hold (individual P&H current control)
- Dual Knock
- 4MB of logging memory
Both ECU's have:
- 8V out
- 5V out
- Trigger in = 2
- USB Coms connector
- Can Bus Coms connector
- All spare injection and ignition channels can be auxiliary outputs
Trigger support for the following patterns:
All Mitsubishi 4 and 6 cylinder.
All Subaru 4 and 6 cylinder
All Nissan optical
BMW S50
Buick 3.8L
Ford TFi 4, 6 and 8 cylinder
Ford 36-1
Ford Cosworth RS500
GM LS1
GM LS7
GM LT1
Honda K20
Honda S2000
Honda V6
Motronic 60-2
MX5
Porsche 944
RX7
Suzuki Baleno
Toyota 36-2
Toyota 2NZ VVTi
Toyota 1ZZ VVTi
Toyota 3SGTE VVTi
Toyota 1UZ VVTi
Toyota 1JZ-GTE and 2JZ-GTE
Toyota 1JZ-GTE VVTi
Toyota 2JZ-GTE VVTi
Other patterns can be added quickly with the correct information supplied.
Plug-in ECU:
Subaru 1994-96 (V44)
Subaru 1997-98 (V44)
Subaru 1999-00 (V44)
Subaru 2001-05 2L (V44)
Subaru 2005-2007 2.5L (V88 with DBW)
Mitsubishi EVO 1 to 6 (V44)
Mitsubishi EVO 7 to 8 (V44)
Mitsubishi EVO 9 (V88)
Nissan N14 (V44)
Nissan S13 (V44)
Nissan S14 (V44)
Nissan S15 (V44)
Nissan GTiR (V44)
Nissan GT-R (R32-R34) (V88)
Nissan GTS (R32-R33) (V88)
Mazda MX5 1.6L (V44)
Mazda MX5 1.8L (V44)
Mazda 323 GTX (V44)
Mazda RX7 (V44)
Toyota MR2 SW20 (V44)
Toyota Celica ST185 (V44)
Toyota Celica ST205 (V44)
As you can see this is quite an extensive product and very well engineered and produced. It is far superior than the Autronic in a few features especially over-run control. Personally im itching to get it in the car and try it.
Depends how nuts you want to go, the bikirom daughterboard (running version 3 software) is more than good enough in the R34, especially for the price. You've got full access via USB to most of the maps you'd want to frig with. The only thing V3 is missing is real-time upload, but that's been sorted with V4 anyway...so bit of a moot point.
So easy to tune now it's sickening, shame it was like this out of the box 2 years ago, took time to develop I suppose.
Yeah, but they wanted to make sure when it hit the market it hit the ground running...
having the thing not up to scratch would have given the product a bad name from the get-go and something that would have been hard to shake.
The thing is constantly under development and even last week underwent quite a number of needed changes after tuner feedback.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
