Vi-PEC skyline plug-in is $1750 and has the map sensor built in. It runs all the factory sensors and AFM support is due on the next firmware upgrade.
Ahhh ok .. I thought these things would be a lot cheaper since they're new and trying to grab a market share. I can get a PFC for less than that and it's 'proven' technology (just saying, in terms of $$$ not trying to start a flamewar)
What's the diff between the plug-in board and the full ecu ?
  • Replies 895
The difference between this and the powerfc is all the extra features. If you look at it from a price perspective a powerfc + z32 afm + boost controler cost more than the plugin ecu.
Edited by TiTAN
Brand new Power FC's for your car are $1980...lol
http://www.accessauto.com.au/Items/ap-414-...20GTT%20RB25DET
Thats a $230 saving already!
Then if you want to make any decent power you need a Z32 $300 + plug $35
Then maybe some electronic boost control...add another $500
http://stores.channeladvisor.com/access-au...st%20Controller
its starting to get expensive isn't it...you are getting almost $200 change from $3000 and you are still left with a very basic product that in my opinion and everyone elses who has first hand experience with both products, wont run your car as nice as the Vi-PEC.
The plug-in board is the full ecu...designed with the STD Nissan plug and designed so its easily screwed into the Nissan ECU case. Nice and discreet to avoid defects, theft, voiding insurance claims etc..
Edited by DiRTgarage
you do have a point but R34 pfcs can still be found for around $1400 (one went for that price just recently) 2nd hand .. and most people already have an ebc. But yeah if I didn't already have an EBC installed and was looking for an ecu this would probably be my choice to.
How much for the V88 ? I take it the major diff is the knock detector?
Im just compaing like for like...Vi-PEC's are brand new...not 2nd hand. The knock amp for the plug-in can be purchased from a dealer. For a road car the V88 is overkill but ill get you a price if you like.
I would have to disagree dirt. The power fc can run your car as "nice" as the vi-pec can. However, this mainly applies to stock rb's so if you only have a stockish car with stock turbo then you wont need a bigger afm or a boost controller so you would probly be happy with the limited power fc.
Only problem with that is once you have the power fc then you are stuck with it, once you start doing some mods you will need a decent boost controller ($600 for PFC kit) a Z32 AFM + plug and then you still have a power fc which suffers from many issues that a modded car with a power fc have.
So you want to upgrade your stock ecu ? or your getting serious about your Skyline and you want to move to power gains... The Vi-Pec is a far better ECU for the job. Do the job properly the first time - do the job once and be done with it - You will save lots of money in the long run.
Fair call...but who here drives a stocker?...a few examples above have highlighted that the Vi-pec runs the car better in most instances. Mark just did a V88 in a completely standard 2JZ Supra and finished with a car that ran smoother than the stock ecu could.
Alot of people have stockers here, and they are the ones where the power fc will be a good choice. If anyone has a stocker and needs a ecu to start modding their cars.. the bug will bite and mods will allways follow because the power gains you get is never enough so if you get the vi-pec to start with then there will be no brick wall or expensive upgrades needed in AFM's / Boost controllers / Launch Interfaces that you will need extra because they are not needed with the V44.
The V88 is a far advanced ecu is only needed for very serious race cars.
I agree, my car was stock, installed a V88 and everything improved, cold & warm start, idle which are things you would assume the stock ecu would do better, not so. V88 is the ants pants!
not everyone can justify a V88 for a stock car unless they have big plans for the car in the future which I am going to give it a big guess that you have big plans :)
If not then it is always good to have decent management from the word go even if your not going to mod the car for a long time, at least you know the job is done and it does not have to be re-done ever again.
lol...the ants pants...haven't heard that one for a while. Time will be good for this product as it is human nature to be aprehensive about new things, change etc.
I am not answering this question. It has been answered 20 times or more since the thread has been started.
Well I sifted through all the crap and for those that care, it seems a you need a knock amplifier board which is an additional $240.
Edited by bubba
Or if you are more confident with electronics KC5444 from jaycar for a whopping $16.95. though you need to build it, make a case for it and make all the wiring for it and then once its all setup tune the amplification so that its not missing the knock or making false knock readings.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
