Quick question about the optional driver box for the V44 , does it have peak and hold drivers for four injectors in it or is it just a resistor box to limit current if you use low impedance injectors ?
It would be nice if the V44 was available with the 10a peak and hold drivers , can they be a special order that way ?
I can't get into their forum or I'd ask there .
Cheers Adrian .
  • Replies 895
one little quibble I have with this ecu is the fact you cant select between low/high impedance injectors as you can with many of the other higher end ecu's
are there any explanations for this?
you can with the v88...its only the plug-in boards that have this feature missing.
a solution may be on the cards for this issue
Cool I will look forward to hearing more but for now I'm just going to use a resistor pack.
oh ok good to know!
  • 1 month later...
With the vipec plug in, does it use the V44 boardin your standard casing? also will it support standard GTR injectors, because from what i read, it has some problems with low and high impedance using resistors. because if my afm are buggered im seriously considerign getting on of these, but only if itll run with a stock car once tuned.
Yes, yes, no and yes.
This ecu has been given the honour of being named the "Best ECU" in the latest "Best of the best" High Performance Imports magazine.
The real engine management "leckies" would know for sure but my research leads me to believe that the peak and hold circuitry is different to the saturated system .
PH injectors I believe tend to be low resistance high current ones where saturated ones tend to be high resistance low current .
I've been told the quick dirty method of running high current injectors in a saturated system is to splice in the resistors but you don't have the peak and drop current to snap open and hold the pintle pin like a PH system does .
I did actually speak to Ray Hall and his response is that the V44 is aimed at a price sensitive market segment and I gather to be price competitive had to sacrifice the peak and hold injector drivers and go with the more common trend towards saturated injectors .
Please do NOT make the blind assumption that I'm saying the product is cheap and nasty , the trouble is that so many buy everything on price and if it was made in Xxxxx and sold for $4.99 lots'd buy it .
Something I did read in Honda circles is that someone out there is making good reliable 1000cc saturated injectors and apparently they at times work allegedly better than existing PH ones .
My problem was that getting "affordable" hose barb/tail saturated injectors is not too easy where PH or high current ones are easy and cheap . No good for a wire in V44 though .
My answer could be to use Mazda Rotary turbo O ring injectors and machine shallow rings into them for the short length of rubber fuel hose to bite into under the clamp .
If I could buy a V44 with PH drivers/circuitry I'd do that so Guilt - spill the beans .
Cheers , Adrian .
Cheers , Adrian .
He can't "spill the beans" but lets just say the Vi-PEC is evolving. This has been deemed necessary to completely separate the product from another one similar. A lot of the Vi-PEC intellectual property will cease to exist on the similar item. The Vi-PEC brand will be regarded as a world leader in ecu technology and needs its own identity to achieve this. I am of the belief that a lot of features are being held back until the evolution is complete.
I already think i may have said too much...enough for now.
Maybe i should wait for it to evolve and then pick it up with all the gucci stuff.
the chipset will be no different...its just a firmware upgrade and new tuning software if you have already have a Vi-PEC.
The whisper is the new tuning software is the ducks nuts.
I really should STFU...lol
Edited by DiRTgarage
You can call it want you want but the vipec engineers are still the same bunch of engineers that work at Link electro systems NZ. Its funny you call it "Vi-PEC intellectual property" but then there was nothing wrong with giving Link an sm4 plus someone elses "intellectual property" data and telling them to pull it apart and do better.
This does mean the worlds leading ecu will still be made and designed by link in NZ with a few wants put into it by vipec. Do you think Link would want their ecu disadvantaged over the vipec "version" This would take a good sum of money to pass into links hand as remember its them doing the building and designing with wants from vipec. Vipec cant and doesn't make ecus !
Also remember there are ecu's out there that make Link g4/vipec ecu's look very very simple and always will, a vipec will never be the "best" or have the best best technology compared to the likes of pectel or life racing ect...
HA!
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
