hey,
im about to put gt-ss turbo's and tomei poncams on my gtr and im deciding if i should by tomei exhaust manifolds
iv done some reading and apparntly they arnt really needed but what i want to know is do they change the sound of the car?
basically i want my car to sound tough
thanks
sorry but i have to laugh...
want it to sound tough?
Thats your reason for spending $1000 on an item thats not needed?
You might aswell spend $800 on a set of big cams too that aren't needed :)
Honestly, it'll probably change the note a tiny bit, but nothing major IMO as the actual design etc isnt much different from factory.
It'll give you a little more power (by being less restrictive than factory), and probably spool the turbos a lil quicker... but its your money man.
I personally wouldn't bother unless the engine is 'built'
I was considering a set of these for my R32 GTR when I build it with a 2.8 kit.
For the dollar value are these a worth while upgrade option? does the quicker spool time and extra power justify the expense?
Has anyone out there done an actual dyno comparision of tomei manifolds vs stock in terms of spool time and net power gains?
cheers
rob
cheers
rob
1. no
2. yes
latest HPI mag did an article on unnecesary upgrades. R32 GTR making 306rwkw, they put stock exhaust manifolds back on (was tomei i think), stock cams back in (tomei poncams), stock fuel pressure reg (cant remember)back on and i think there were a few other things too, all in all the car lost 1kw, yes one, just ONE killerwasp :domokun:
1. no
2. yes
shure it lost one kw in the top end (peak power) but what did it loose in the low/midrange? torque? I dont care what the number on the dyno sheet says, its all about how the car drives and thats all about low/mid response and tourque. I would bet my left nut that it was a fair whack worse off in the mid range....
very random, and as for midrange power on the GTR, they were very close, almost a trace of eachother on the graph
just read it again, car as it was for the second run:
HKS GTSS turbos - as before
factory exhaust manifolds - were tomei items
factory cams - were tomei poncams
factory water pump - was an electric item
sard fuel pump and 700cc injectors - as before
doesnt seem right that the graphs are so close with a change of cams, but it sorta makes sense to me, it moves the power band higher where the torque is dropping off because everything else is designed to come in earlier, so it sorta balances out? thats how it works in my head anyway lol
and no, i cbf scanning it. next time u walk past a news agency just pick up a copy of HPI and go to page 56
Edited by VB-
1. no
2. yes
latest HPI mag did an article on unnecesary upgrades. R32 GTR making 306rwkw, they put stock exhaust manifolds back on (was tomei i think), stock cams back in (tomei poncams), stock fuel pressure reg (cant remember)back on and i think there were a few other things too, all in all the car lost 1kw, yes one, just ONE killerwasp :banana:
well then if HPI says so...... I thought that was a catalogue magazine for people who want to buy neons for their car. Actually did they find adding neons increased power? I was hoping to buy some, oh and a tomei manifold and order some take away...something with rice in it. :)
HPI Serving suggestion - rice.
To answer this blokes question properly the GTR 'is' tough... even to a deaf man.
do you actually read hpi? find me one car, or one add for neons.
its a magazine, im not taking what they say as gospel, but its more believable then alot of other bullshit that gets posted on here...
agreed.
latest HPI mag did an article on unnecesary upgrades. R32 GTR making 306rwkw, they put stock exhaust manifolds back on (was tomei i think), stock cams back in (tomei poncams), stock fuel pressure reg (cant remember)back on and i think there were a few other things too, all in all the car lost 1kw, yes one, just ONE killerwasp :blush:
It doenst make any sense.
Adding aftermarket parts doesnt mean it will give an instant hp gain.
It all depends on whether the car is tuned to the new parts installed.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
