im trying to work out what wheels to get for my stag.....does anyone know how much tollerence the attesa system has for rolling diameters? the rolling diameter of a 205/55r16 (the stock 16" wheel) is 632mm and the standard RS4s mags are 215/50r17 with rolling diameter of 648mm... how much either way can we go without upsetting the attesa?
D.
https://www.sau.com.au/forums/topic/219178-attesa-question/
ahhh... the question that has been sked and answered a thousand times....
heres my answer from last time someone asked -
For long term issues tho, i nutted this out - this is my reasoning as to why something that seems so inconsequential can cause dramas -
A difference of 10mm in rolling diameter (Say 660mm front and a 650mm) rolling diameter rear tyre is a different of 31.42mm difference in distance travelled per rotation. Given that each rotation of a 650mm diameter tyre is about 2050mm, your larger tyre would rotate about 65 times every time your smaller one does 66times. So your larger tyre will have rotated one less time than your smaller one every 133 metres. If you do 1000 km a month, so 12,000km a year, then its a matter of your clutch packs coping with a difference of 90225 rotation difference every year. Thats a lot of wear and tear on your clutch packs, from a difference of 10mm.
if you have 225 tyres with 40 section, and 225s with 45 section, your difference in diameter will be 22.5mm (45% of 225 - 40% of 225, then multipliy it by two as we're dealing with diameter, not radius), so double the above figure. A differene of rotation of more than 180,000 times is what ur gonna get. How long do you think your clutch packs will last.....?
Hope that A) that makes sense and that B) my maths is correct!!
Bobbeh
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3865911
so you're saying that even 10mm can be fatal over time?
the RS4s wheels are already 16mm larger rolling diameter than the standard 16" wheels... would the manuals have been adjusted at factory to suit this or are all manuals running their standard 17" wheels going to burn through clutch packs quicker than autos?
and, should i be trying to match rolling diameter of the standard 16" with the factory 205/55r16 or the 17s that came on my manual?
D.
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3865946
it doesnt matter what the rolling diameter is - what matters is that is it the same rolling diameter front and back.
and yes, im saying it will be damaging over time. It is not the issue of changing the diameters, that doesnt hurt. Just make sure there is no difference between front and back.
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3865995
so you can garruntee that changing the diameter wont effect the system, as long as they're all the same? coz i've been told that it will cause problems
D.
As long as the front left, front right, rear left and rear right wheels (wheels = rim and tyre) equal the same diamater/circumference, then you're safe.
For example, I'm running 235/40 tyres on 18" rims all round = no problems.
Apparently the ATTESA system can't handle even the slightest differences in circumference ... something I'm reading about at the moment for myself.
:O
Edited by RubyRS4
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3866133
What happens when your 8mm deep tread wears down to the 1.5mm wear bars...? thats a 15mm change in rolling diameter. Doesnt matter. As long as front and rear is the same. The atessa system wont even know that the diameters have changed, as long as they are changed equally. only issue is that your speedo will be out. Bigger diameter means that your car will travel further with every rotation.
D.
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3866565
yes that is very likely the reason. new rear tyres or just swap front to rear.
BTW it is difference front to rear that matters not the difference to stock wheels. I run 245/45/17 on mine which is pretty big - but no problems with attessa
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3866704
If you're talking new tyres (8mm deep tread) front and worn tyres (1.5mm wear bar) rears then its:
8mm - 1.5mm = 6.5mm
6.5mm x 2 = 13mm
Thats a 13mm change (not 15mm) in diameter :D
Sorry couldn't help myself :P
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3867394
So if I do a hard left the inside tires will do less distance than the outside tires then a km down the road I do a hard right everything will right itself (just kidding) I plan to get new tires for the rear very soon. LOL
I am going on a trip this weekend so I will swap front to rear and see how it goes.
Thanks for your help.
https://www.sau.com.au/forums/topic/219178-attesa-question/#findComment-3869927
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
