I have the following for sale (prefer Melb buyers):
- R33 GTR standard intercooler, perfect condition, no bent fins or damage $700
- R32 GTR gearbox done 80,000km, 4th gear synchro worn, can test drive, still in car (posting for a friend) $1000
Please don't reply saying you can get these parts cheaper elsewhere, if so go get it!
Cheers
https://www.sau.com.au/forums/topic/21937-gtr-intercooler-and-gearbox/
Standard GTR intercoolers are definetly not the same as a GTS-T. They are a front mount, not sure on the dimensions but about 600mmx276mmx76mm?!?
Definetly a worthy upgrade for any GTS-T.....
vspec2 - the price is negotiable on the gearbox
Jamezilla - cheers mate!!!
Adzmax - difference is one uses push type clutch (R32) the other uses pull type clutch (R33). Intercooler is good upgrade for any GTST/GT-T, they flow up to 500hp!!!!
