  • Replies 547
Posted Images
Anyone after some 17" slicks going cheap?
Got one set of 24/69/17's for $240 (firm price) with heaps of tread left, they've come from a team who used them for one testing session. They're basically a 240/45/17 - i put one of them ontop of a 235/45/17 street tyre ive got and cant tell the difference except for the massive difference in grip between the two :)
Ive got 2 sets of them, and once my new brakes go on the car it needs 18"s so someone get a bargain
Got one set of 24/69/17's for $240 (firm price) with heaps of tread left, they've come from a team who used them for one testing session. They're basically a 240/45/17 - i put one of them ontop of a 235/45/17 street tyre ive got and cant tell the difference except for the massive difference in grip between the two :D
if only you'd posted that last week, just went and bought some semi's in that exact size :)
Sorry mate - how much were the semi's?
i got 205/45/17 on mine at the moment...
if i can confirm attendance on 21st ill definitely opt for a set.
Ok cool, let me know
take it your only selling the two? would be interested in all 4 at 120$ each.
when is the last day to be able to attend?
What do you mean?
Last day to pay???
Is it still in time for applying SAU member and CAMS license???
As soon as we see that you have applied for membership and the money has been transfered we can put you down as a member even though you haven't received your membership pack.
As for the cams.. You may be cutting it close. it usually takes 2 -3 weeks for cams to turn around your application but you can give them a shot..
You shouldn't need a CAMS licence for this event - a AASA licence can be obtained from Wakefield on the day (12 months around $50)
Also (correct me if I'm wrong SAU admins) but as SAU NSW is a CAMS affiliated club (not that you need CAMS for this day) you should be able to fill out the forms and pay SAU and get 12months CAMS on the day, keeping the 28 day stubb at the bottom of the form. The catch may be that there won't be any club admins there on the day who have the authority.
i've got another question, my power steering pump belt isn't in the best shape, is it likely to fail scruitenering or is it too hard to make that call with out seeing it? i'll try n change it before, but incase i dont get the chance
When it sells out you will have missed out but just before then is ok. The catch is that we don't know when it will sell out. Looks like coming down to the wire this time.
This is correct Michele.
$17 and 20 minutes. Even if you buy it and then fit it on the morning at the track it's worth it.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
