  • Replies 87
Is anyone going to come up with an actual model or part no??
I have a friend who owns a specialist 4x4 workshop and he carries at least half a dozen different clutches for the various year and models of the Patrol, and, they are not interchangeable.
  • 2 months later...
  • 2 months later...
the power limit would be like the amount of torque a patrol can throw out, plus its in a 2 ton vehicle. But I still wouldn't take it past the other daiken exedy H/D limits which are rated @ 450hp - I reckon they are a bit overrated powerwise.
Sumo
Well how come the part number for the Daiken HD for a Skyline is R5208HD...
I have spoken to both Daiken distributors and to Coventry Auto, and have recieved the following information.
"The Nissan Patrol Clutch kit will fit, it has a higher rated pressure plate than the standard Skyline pressure plate. Noting this the pressure plate is rated so as to match the torque characteristics of the Patrol engine, despite sharing similar flywheels, clutches are designed with different applications in mind."
and this
"The Skyline HD clutch has an uprated clutch plate compared to the Patrol Clutch plate. The clamping pressure is similar however the the combination of varying clutch and pressure plates are designed to take either big torque low rpm, big torque high rpm or any combination in between."
or
"We do not recommend the fitment of a Patrol Clutch to a skyline and vice cersa, they are designed for different purposes and the clutch compound is different for both kits"
Don't kill the messanger, this is the info I recieved.
just thought i'd chuck in my 2 cents, even though the two clutches would be made of different compounds the low down grip and clamp that the patrol harnesses for distribution thru 4 wheels SHOULD be a godsend for hard as fu** launches, i suspect what daiken have in mind when doing their extremely expensive r&d is how fast is the clutch going to spin with what amount of torque thru the rev range and what sort of pressure can be applied to said clutch at different points. BUT i still reckon that it is worth a try, i mean what is 5-600 bucks in the scheme of things if you are going to find cool shit that that can be cross fitted, my clutch is starting to slip too and the patrol clutch is going straight in, why not. least i know it wont fall apart on me when racing me some commode-whores! Peace.
even though the two clutches would be made of different compounds the low down grip and clamp that the patrol harnesses for distribution thru 4 wheels SHOULD be a godsend for hard as fu** launches.
You really think that Daikin chose a clutch plate material for Patrols that will withstand hard launches? How many people do you see doing high rpm launches in their Patrols?
Just because it fits, doesn't necessarily mean that it's suited to the application, is what Daikin is trying to say.
I wouldn't know what to think. There are several people here with Patrol clutches now. To you guys - How many hard launches has the clutch withstood so far?
what i was saying that is with a 2+ ton vehicle running a 4wd drivetrain, made to take the extreme pressure that mud, sand offroad etc would put on the clutch and p/plate that hard launches should be a sinch, i realise that the rpm is different with launching a line and a patrol, but it is made for a pretty heavy duty application.
this has all been extremely interesting, i feel so conflicted. i will now consider a patrol clutch. one thing no one mentioned is the torque that a 4WD has. id have to agree that if a patrol clutch can take the low end toque, it should handle high rpm dumpage from a relativly light car, for a little bit anyway.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
