  • Replies 43
Posted Images
In,
Disclaimer - I've seen the pics from Texi and i WILL NOT partake in any black dildo festivities :D
Accomodation request - DECLINED :D
All attendies must bow and 'present' before B.B.C ;)
:w00t::D:)
ROFLCOPTER x 11tybillion
Im sure it will be a civilised evening within the cigar lounge, sipping brandy and snacking on scones......... ;)
Edited by A31Deviat
Accomodation request - DECLINED :down:
All attendies must bow and 'present' before B.B.C :)
>_<:):D
:D
B.B.C? didn't they sing "Do me" and "Poison"
OK, no more crap.
As said count me in.
Accomodation request - DECLINED :)
:teehee::geek::P
Im sure it will be a civilised evening within the cigar lounge, sipping brandy and snacking on scones......... :)
bwahahahaha.... so guess Im packing the BBC then huh??
OK guys we have plenty of interest, il be contacting Mikes tonight/tomorrow with rough numbers...
Stay tuned for price update and formal payment/info post :D
nah not me Mitch, you know me, working every sunday ;)
who works on weekends. :D
hate to say it but i'm getting quite bored not being at work :). trying to do stuff to the car but only got 1.5 hands to work with, gets very frustrating ;)
might stay down the saturday night aswell, is any one else going to stay saturday.
We will be staying the second night as long as Daves workload permits... I think they have a round on soon after?? Il check and let you know!
Kel and I need a spot
Updated :unsure:
Count me in for Friday night Spanna!
thanks
Liz.
no dramas :)
gotta work on the friday so probably wont get there till 8.30pm
wont be a problem.... I finish at 2 and will be heading up then.. im sure there will be more late arrivals. Will organise for people arriving late to have keys etc as the usual is to go out for dinner the night before.
Il also be staying the saturday, any others interested please let me know.
Il update the first post or start a new thread re definite payments and spots. Just waiting on one more confirmation from Mikes.
Cheers
Anna
Spanna,
Andao, Chris and myself are def keen for the sat night, so book us in y0!!
p.s. happy b'day :)
Wha? Am iz azian now? :cheers:
Um me thinks chubbs had a few too many beers!!! lol
I definatley know chris and I are not staying Sat night and i'm pretty sure chubbs isnt either!! Its just the booze talking, well lack of coherant talking i should say!! :(
Hey Anna,
Can you take me off the list, can't make it up on the Friday, will be driving in on Sat morning.
cheers
NO dramas.. :P
Hi Anna. I'll grab a room for Friday night if there's any left. Cheers.
No probs, should be fine.
Im just waiting on a call back tonight re finalising details. Thread will be updated later tonight.
Cheers
Anna
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
