Been wanting to make one of these for a while but i didn't want to put one of these up till i got the spray job and few other things...well here it is...
1995 Nissan Skyline R33 GTS-t type M
RB25DET
Mods- Motor Rebuild, JE forged Pistons stregthened piston rods,Head work, bigger injectors Jasma Twin Loop exhaust, hks power air filter, turbo was rebuilt and converted from ceramic to steel and also high flowed and ball bearing...
Exterior- 400R front bar, OEM sideskirts, X-Racing Rear corners
Interior- AXS seat covers, Stich gearknob, Black and blue gearshift boot and handbrake boot, Underdash Neons, Autometer 2inch boost gauge, autometer tacho
Wheels- 17inch Stich Precious with bridgestone 235 tyres
ICE- Clarion 7inch touchscreen DVD unit, Pioneer splits and tweeters, pioneer 6x9's, Kenwood 550w 4ch amp, Pioneer 760w mono block, Kenwood 1500w subwoofer
well guys here it is pics of when i first bought it wit the ugly big chromies, then before with the whole stock look, and now with it all done. let me know what you think
When i first picked up the car
https://www.sau.com.au/forums/topic/219752-dales-r33/
  • 10 months later...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
