Those turbos are good are upgrades for MX6s... thats about it.
and other sub 2.0L engines, charade / swift / starlet
cheap as chips and can flow 150-200kw without too much drama
but deff not worth the money of a custom exhaust manifold or adapter / cooler + exhaust plumbing modifications for a skyline
Reason?? Got one lying round and mines on the way out...
No matter, decided to spend some money and get a KKR480 instead.
Opinions??
KKR are good for the money. Get a price on it and I will see if I can better it for you INC postage. PM me . >_<
  • 1 month later...
I'm running a KKR480 on my Rb25 motor, it's not as bad as people make out (spools quicker than a standard RB20 at least lol), but my VCT is disabled, don't know if that would make it any quicker to spool, but yeah I know another guy who went and bought one after seeing mine.
Remember these are the same turbos used on the GenTT twin turbo kits for the LS1 :laugh:
That said, if I were to buy a new turbo I'd go for a HKS one if I could afford it.
Remember these are the same turbos used on the GenTT twin turbo kits for the LS1 :banana:
I'm almost certain they are KKK not KKR will go check.
I stand corrected was another article of a TT LS1
Turbocharger:
- Twin KKR330 turbochargers
Boost Pressure:
- 0.65 Bar (9psi) @ 2200rpm
Power:
- 450kw (600hp) @ 5700rpm
Torque:
- 850Nm (630ft/lb) from 2500 - 5500rpm
Boost Control:
- Twin Internal Wastegates
- With fully adjustable actuator rods
Edited by AndyD
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
