Those turbos are good are upgrades for MX6s... thats about it.
and other sub 2.0L engines, charade / swift / starlet
cheap as chips and can flow 150-200kw without too much drama
but deff not worth the money of a custom exhaust manifold or adapter / cooler + exhaust plumbing modifications for a skyline
Reason?? Got one lying round and mines on the way out...
No matter, decided to spend some money and get a KKR480 instead.
Opinions??
KKR are good for the money. Get a price on it and I will see if I can better it for you INC postage. PM me . >_<
  • 1 month later...
I'm running a KKR480 on my Rb25 motor, it's not as bad as people make out (spools quicker than a standard RB20 at least lol), but my VCT is disabled, don't know if that would make it any quicker to spool, but yeah I know another guy who went and bought one after seeing mine.
Remember these are the same turbos used on the GenTT twin turbo kits for the LS1 :laugh:
That said, if I were to buy a new turbo I'd go for a HKS one if I could afford it.
Remember these are the same turbos used on the GenTT twin turbo kits for the LS1 :banana:
I'm almost certain they are KKK not KKR will go check.
I stand corrected was another article of a TT LS1
Turbocharger:
- Twin KKR330 turbochargers
Boost Pressure:
- 0.65 Bar (9psi) @ 2200rpm
Power:
- 450kw (600hp) @ 5700rpm
Torque:
- 850Nm (630ft/lb) from 2500 - 5500rpm
Boost Control:
- Twin Internal Wastegates
- With fully adjustable actuator rods
Edited by AndyD
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
