Looking to take my car back to near on standard ready to sell as it never gets driven any more and i'd lose too much money selling it outright.
So for a lucky RB20 powered R32 owner i'm offering this to you, would much prefer a couple of minor motor mods on your rb20 at this price.
I owe no money on the car so therefore i'm in no rush to sell the car and am willing to take my time and be patient but in saying that i've priced the package up to sell not to dream.
Andrew/Joel: can i please leave this here for a couple of weeks then move it to the 4 sale section?
Basically i'm looking at 2 options for now:
1.) Give me your motor, gearbox, clutch, tailshaft and $7500 and i'll give you my motor, gearbox, clutch and tailshaft. (highly recommended option)
2.) Give me your motor and $5500 and i'll give you my motor
Mods are as follows:
Fully rebuilt Rb30 (has less than 7000kms on clock)
R32 Rb25de head (non vvt), fresh. GTR valve springs. (new valve stem seals etc)
Cleaned and flow tested GTR injectors (600cc injectors at an extra cost)
Z32 AFM
Adjustable cam gears ('aerospeed')
Garret GT35/40 internal wastegate (ford xr6 turbo) With 15 psi actuator
Apexi AP Engineering power fc with hand controller
Custom reground GTR cams
Custom catch can (optional)
no BOV
modified engine mounts
Rb25 Gearbox (91000kms)
Triple plate OS Gieken clutch (1000hp)
Modified tailshaft (to suit rb25 gbox)
(Engine bay i've tried to make look as standard as possible to keep 'prying' eyes away)
Motor is currently making 250rwkw's @ 12psi as seen at last sau dyno day (Boostworx). All thats needed to see 300+rwkw's is the injectors i've given as an option and a boost controller. This is the cheapest way an R32 owner will see 300rwkw's reliably!
Before anyone asks, no this can't be made legal (in an R32) in the eyes of police/regency and that the reason my car isn't over the top and when you pop the bonnet on my car it looks like a stock rb20 to 'most' people, i've had this motor in my car for 2.5 years and haven't had an issue even when it was a daily driver.
https://www.sau.com.au/forums/topic/219964-want-an-rb30det-in-you-r32/
  • Replies 43
I think Adrian (rad33) is interested in this!?
he is but doesn't have the cash at the moment.
By the way the motor is still in the car and will be until i take a deposit so the the prospective buyer can test drive it!
DAMN, this would be a torque monster!
i want it :(
thats the best thing about this motor.
Have had a few pm's about seperating parts, really only want to stick to the two options for now but may contemplate seperating later down the track if i can't get a sale.
Ahh such a pitty. :(
Hardly driven. :P
i know, its killing me and i know i'll probably regret it when its gone but i need to get something more practical, i really wanted to take it down the 1/4 too, hopefully A.I.R's done soon and i can take it for one run!
In all honesty mate, been almost a year since I sold mine and I only miss it occasionaly. I don't miss having to watch my mirror
constantly for cops and all the hassle that goes with it, or the expense of running/insuring it!
Its awesome to drive down the 'bay or town whenever you want and not have to worry about police attention!
Good luck with the sale mate, someone will pick up a bargain
your probably right chris as i will still be getting another performance car but something thats a little more practical and something that the mrs can drive.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
