ok folks
drifty here
i have an r33 series2
standard
apart from decent exhaust front mount an a bleed valve
it was going fine
and then the water pump blew
after that i think it started once
an then went to start it
and it just kicked over
but wouldnt start
now im triying to fix it
and i went to start it
and all it does it go click now
wat the bloody hell is going on
can sum1 please help me
pm me
messge me
please
i really needa get this car goin now
but yea all i get i a lil single click in the engine bay
an thats it
i get reds but no kick
thanks follks
https://www.sau.com.au/forums/topic/219979-help-me-i-cant-start/
dude - I am only saying this cause nobody more knoledgable has come along yet !
ok - basics - 3 things needed to get a motor started - fuel - spark - something to turn it over
so yeah.. just make sure its not something as simple as a fuel pump failure
you can test this by VERY CAREFULY taking the fuel rail feeder line off and just see if it spits any fuel out when the fuel pump prrimes .. TAKE CARE doing this!!!
and - take the plugs out and see what condition they are in - I had a pulsar that wouldnt start and it turned out that all the plugs were saturated by fuel - replaced em and all ok
its a bit harder to check for spark on a car that has coil packs - so maybe someone who is smarter than me can come in and suggest a few things..
but yeah.. just make sure all the basics are good and see where you go from there.
also your starter motor might be seized - apparently banging it with a rubber mallet etc might help
I am in no way a expert mechanic- but you didnt seem to be getting many replies so thought I would put some basics in here
hi
if its ticking, kicking (tick,tick,tick) and it doesnt start i would take a nice piece of timber and punch fuel tank near fuel pump(back or front, dont know where is it in skyline), it can be fuel pump fault. or starter but u mention kicking not ticking(if ticking hit starter it like fuel pump.BOTH THING MUST BE DONE WHILE OTHER PERSON IS STARTING THE CAR. dry engine. thats what im doing when car doesn t want to start. usually its nothing seriousS
good luck
A click or "clink" noise when turning the key 99% of the time means the starter motor is not getting enough power.
Get a multimeter (if you dont know what one is, then call RAC now coz your no help to yourself) and put the leads from the multimeter on your battery, it must read 13v to kick the motor over... if you have less than 13V , take your cars negative and postiive "leads" off the batt, and test again, once again , it should have around 13V?
if it does, then the motor should at least turn over and if you wanna talk sounds , it should go "RARARARARARARARARA" but not fire.
Once you got it to that stage, if its not firing then its a fuel / spark related problem. or possibly a fuse, check your fuse kick panel near drivers side footwell.
If you are too n00b to do any of the above, then call RAC and pay some money until you upgrade your brain matter coz one day it may matter.
good luck
Edited by coFF33
The single click you are hearing is the starter relay. What you need to do first off is determine why it won't turn over.
When the water pump "blew" did it spray water everywhere? Even a small amount will cause problems with your relays.
I have absolutely no "hands on" experience with skylines in this regard (ex stagea owner :teehee: ) but I would grab a test light or multimeter, a mate to turn the key on and off, and start chasing the wires from the starter motor backwards to the battery, or try another starter if you can.
Also, try getting your mate to bump the key a few times while you smack the casing with a hammer handle - if it is just poling causing the issue this wil l at least alow it to spin freely for a bit, and then you will know that its time to get your starter rebushed or replaced.
ok thanks 4 ur feedback guys
no water did not spray wen it went
but wen it went
the car ran rough an died
it did start again
so i could get it around the corner to home
i went to start it the next day an it kicked
but would not start
so it was winding over but that was it
but alll i get now is a single click wen i turn the key to the start position
the click sounds like its coming from the engine bay sumwhere
battery is brand new
have tried 3 different batterys so far
so i have eliminated that
jus tcant work out y it was starting
then only kicking over
and now nothing
scary
any more ideas guys
as i am starting to wonder if its a relay stopping power getting through
ill keep u all up2 date
and once again
THANKS
You may have filled a cylinder or 2 with water, which basically locks the engine. Try turning the engine over by hand. If it won't turn, remove the spark plugs and try it.
shit i hope that hasnt happened
any 1 in western sydney as im in campbelltown
that would be willing to give me a hand with it
and maybe come and have a look
as i needa get it back up and running asap
im gettin new water pump real soon
so if any 1 could help me out doing that would be much appreciated
cheers guys
undo the sparkies, and crank the motor over by hand a couple of revolutions, then do it by key, as above, water will not compress. all it will do in that situation is bend a conrod.
step two check the oil make sure it isnt mayonaise looking , if it is you have your self a blown head gasket/buckled or cracked head.
step three pull all the relays outta the box and dry them check all the fuses etc
check the starter motor wires, ensure all plugs are connected....
leave your battery on charge overnight, while thats happening gap your spark plugs down to .8. it will make them
easier to ignite with a weak spark. give em a clean aswell......
when the battery is charged chuck it back in leave the key in the ON position
Undo the CAS and give it a turn, you should hear the injectors start clicking and within a few turns if your listening
you'll hear the fuel pump, start.
if it wont fire pull the first spark plug out along with the coil and rest it on the plenum crank it over and watch for the spark
numbers 2345 and 6 are not important, number one coil has the sensor wire on it that tells the ecu to start its ignition sequence, as long as number one is firing the rest will fire.
if you have spark but still wont run pull the fuel pump relay and crank it over,
undo the return fuel hose from the fuel rail. The hose with fuel filter inline and stick it in a bottle. plug the relay back in
(after swapping it with another relay) and turn the key on.....
if you get fuel in the bottle you may have an airlocked fuel rail.
place hose back on and undo the fuel pressure reg (front end) and repeat proccess untill fuel flows with out air bubbles.
thanks for your help mate
much appreciated
atm im in the middle of putting in a new water pump
so after i sort that out i ill get down to business and see how i go with ur ideas
cheers mate
Drifty
also by the way does any1 here hae a lower timing cover as mines f**ked
lol
I have a similar problem with my L24E 30. Turns over fine, but no fire, not even a kick. WHen I turn the ignition on, I can hear the pump run, but nothing. Have checked all fuses, and done a quick re-arrange of relays (as much as I can, I don't have any spare green ones for the pump, ignition and ECU). It started and ran fine on Friday, but after sitting all weekend, I went to start it to go to work this morning, and all it did was turn over. Sounded normal, but just won't kick.
Mine seems to be the (blown) head gasket finally giving up and filling my chambers with oil/water. Was blowing a LOT of smoke on Friday when I last drove it, so it makes sense, and the plugs were (and probably now are again) completely wet with oil. Looks like it's off to get a new gasket set.
I think your battery's flat... new, powerful etc - ok fair enough... but you've cranked it heaps of times... usually if you crank it like 20 times over, say, a period of 20 mins or so, the battery will die so try connecting a jumper lead to it with another car and jump start it.
Also check all your hoses - a hose leak, say, to your BOV will prevent the car from starting up... check your exhaust piping and finally check your spark plugs... try this first then come back and I'm sure someone from here will be able to give you more suggestions.
Good luck!
thanks for your feedback guys
but as i have said the car is not kicking over
but when i turn the key to ignition i get ignition and then continue turning it to start it just goes click once and "THATS IT"
cheers
any more feedback would be good
Drifty
hit your f*kin starter motor with a hammer that will turn the engine, and if it doesnt fire then
it will be your starter.. try jump starting it aswell..
ill give that a go when i finish doing the new waterpump
any thing u guys reckon i gotta be careful of or any good tips to use or watchout for changing the water pump
eg any thing i needa no bout the timing belt an wat not
cheers guys
Drifty
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
