Hey everyone,
When my turbo died a month or two back I managed to lose 2 of the copper washers from the coolant line banjo bolt to the turbo. I checked out the usual autoparts stores, even tried a workshop who suggested that it was an 'odd size' and you couldn't get it. So he gave me some compressed paper washers that were a better fit and said to use a little gasket sealer to stop it bunching up when tightening the lines back on.
Well now that coolant line seems to be leaking. Where do I find proper 17mm copper washers for this bolt? The ones at auto parts stores were all too loose or too small for the bolt, i.e., 15mm or 20mm+.
Fixxxer
https://www.sau.com.au/forums/topic/220162-proper-17mm-copper-washers/
I had trouble finding them too. Went to bunnings, got f**ked off because there were no staff to assist. I found a mixed pack of washers, that had ONE the right size. Rather than buy 4 packs, i opened up them all, and pinched that copper washer, and put them in the same pack.
So maybe you need to look for those mixed packs - and check someone hasnt pinched the 17mm copper washer!
Edited by Trav33
Pirtek will have heaps, so many you wont know what to do, I needed to get some when I re-did the hoses on my Soarer's power steering system, replaced the 2 linked 17's with 2 single 17mm washers, never looked back.
B.
Bahhahah your a true gentleman.
I only needed one washer and like you it was only in that mixed pack for 5 bucks!!!
Opened the pack, pocketed the washer, went and spent that 5 bucks at the hotdog and drink stand out the front.
I figure ive given bunnings enough money over time...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
