hey all
after having my 25 rebuilt and with the intention of installing hks 256/8.8 mm in let and 264/9mm exhaust cam my engine builder instructed me to install 90 pound spring to help with high boost and valve float when larger turbo will be installed so i thought ok go for it.
the problem that i am having now is that after a while when the motor has not been run on initial start up the hydraulic lifters are noisy. engine has been run in and being driven every day with good quality oil. has any one else experienced this problem b4? are there any other causes that would be making this problem evident?
Lifters weren't bled when put in by the sounds of it.... assuming there is no oil supply problem to the head???
Mine were noisy as a mofo for the first week on cold starts.... now I only have a slight noise(one stubborn lifter) which is slowly disappearing... been around a month since mine turned key on the new engine..
U can run a thin oil and take it for a nice long hardish drive and get some oil up into them.... ie high revs... low gear ... under speed limit of course for an hour or so :)
oooooooor take it to a track day and give it a good work out :)
were your lifter replaced when you put the cams in? if not, how many hms do they have on them?
im assuming your engine builder checked the clearences and just didnt slap them in the head
wasnt aware you can "adjust" the clearance of a hydraulic lifter.............
they are very hard to bleed, and most peeps dont really want to pay for new lifters.
as above what anna said :)
the lifters where soaked in oil the hole time the engine was apart for roughly 3 months .
the engine has been running for about 4 months now and still the same.
yes the price of new lifters is way to much atm .
the engine originally done some very high k's
  • 3 years later...
well Im assuming they would of been cleaned, but Im concerned the 90lb springs arnt helping with allowing the hydraulic lifters to function, not oiling up as soon as they could....
90lb is a heavy valve spring yeah???
Im not sure of the brand, 90lb is alot, performance springs dont even know where they would find a 90lb spring to fit....
65lb was recommended... 90lb will cause lifter issues apparantly...
Yes they do say couple mins at warm up stage then all goes quite.
Its just the noise that is annoying.
Confirmed with machinist about spring tension and they are NOT 90 Pounds .My bad for the incorrect info.
They are 65 pound springs as he has installed them in other 25 heads with no problems, it must just be the lifter's worn out and not sealing the
oil in the lifter.
New Lifters a must.
Other then the lifter problem, all is sweet.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
