  • 4 weeks later...
Hi all :)
Does anyone have any Mychron Light TG timers with or without the beacon or similar that would work with the club owned system. Looking for a few extras for Nationals at Mallala on Friday????
A thank you reimbursement may be possible...
Needed by Thursday night for the Friday.
Reply or PM
  • 1 month later...
Anyone got a plug and play ECU for an R32 GTS-T, something other than a nistune, trying to diagnose whether the issues I'm having are injector related or a problem with the ECU.
Needs to work with the MAF and have a plug and play connector, not really fussed which ECU just want to borrow it for a few days.
PM me if you have something, cheers.
Edited by Rolls
  • 4 weeks later...
  • 4 weeks later...
Want to borrow an R34 GTT ABS and TCS Ecu thats located in the boot, mine appear to be having faults come up with the Power FC Hooked in so want to try another module and see if that clears.
PM me Cheers
  • 3 months later...
  • 3 weeks later...
good idea for a thread! id be more than happy to "help a brother out" gettin rid of a defect!
Agreed we import enthusiasts should look out for each other... leaving a deposit is definitely a must so people dont get burnt Edited by Nathangr34gtt
  • 4 weeks later...
1 or 2 19x9.5 20o/s rota grid r. For test fit on c34 rs4s. Just need to make sure of offset before purchase. Should only take an hour I guess however I do work odd shift hours so maybe a couple days? happy to pickup and/or return and provide some sort of deposit if required. Located Adelaide 5049. Pm me if you could help please. Cheers, Lorry
  • 2 months later...
  • 1 month later...
Hi all,
Looking to borrow 2x rims with tyres to suit R32 GTR. I busted up both my LHS Starcorps (unknown model/offset) need a pair of reasonable sized rims to bring to car to a repairer for quotes.
About a week or so max I'd imagine.
Cheers.
  • 2 months later...
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
