Do you think its possible to build an r33 gtr that will do 10sec 1/4mile @ 140mph on pump fuel?
Im trying to get some info for a friend whose looking at building a new car that will go 10sec or quicker yet run 140mph or close to it all on 98 pump gas.
So far he is looking at the 2.8l stroker, usual mods, head work cams, proper fuel set up. Turbo he is looking at the new turbonetics GTK1000.
I know its abit of a hows it going question but any information would be help full. Those who have run 10sec passes could you list your mods and times and mph.
Thanks
h
https://www.sau.com.au/forums/topic/220953-10sec-14-mile-140mph-r33-gtr/
Bobbo here in WA ran 10.2 at 122mph with T76.
The low MPH is because he missed 5th gear and coasted across the line.
The car had 672rwhp and was running a T88-34D with a HKS 2.8L and HKS H-Pattern Dog Box (pump fuel, no NOS).
he hasnt got much aCCess to c16 or so. I know tens in a GTR is doable how ever, what about say hi 9s at 140mph? for some reason his goal is to hit 140mph down the 1/4 on pump fuel at what ever quickest time.
i run high 9's on Sunoco fuel @ 139.6MPH...but im holding the car in 3rd gear so i dont MPH quicker, 9100rpm in 3rd = 139 MPH
this not only affects MPH but obviously the ET as well.
reason for this is i have no parachute and dont wish to be logged by ANDRA stewards for breaking 140
Cars engine is so efficient it only produces 30 more KW on Sunoco than with BP98..so the statement that "race fuel unlocks HEAPS more power" is not correct, it depends how efficient or inefficient the engine is. A less efficient engine will see more of an increase with race fuel. Race fuel in more efficient engines is generally run for safety and a bit of tuning "headroom" (this is the only reason we run sunoco).
so with parachute fitted and pulling 4th gear with pump fuel id say its more than possible to run 9's @ 140 on pump.
Edited by DiRTgarage
How much more ignition timing do you run from BP to sunoco? when i tried BP to Elf turbo max i could easily run 15 degrees more. As you would know simply switching to race fuel does nothing, but gives you the opportunity gain the extra power.
Edited by GTR1993
wont quote our timing figures but only ever run up to 6 deg more on race fuel.
we still make massive power and run the numbers at the track for the set-up we have.
Also have only ever broken 1 engine (oil pump failure) and that was due to over revving and ignition cut rev limiter....not tuning
