Hi Andru,
I was just wondering if you or anyone else were able to help me out with couple of questions regarding MFD installation into my R34 Gt-t. I had the MFD for about 6 months now and only connected the power because I was too lazy to do anything else. But when I bought it, it also came with all the wiring harnesses too. But only thing is my car didn't come with the 3 centre gauges option but instead with the inbuilt gps system. Would I need to buy seperate boost and oil temp sensors? If so how and where would I connect them to and also where I could purchase it from?
any help at all would be greatly appreciated.
regards,
Garland
  • Replies 97
Posted Images
Hi Andru,
regards,
Garland
hey garland
i met up with andru a while back to help me with my MFD install so i know a bit about this stuff now.
to answer your qeustions you do not need any seperate sensors....all the sensors run off your ECU. if your running a Power FC its very easy to just check number pins and connect them to the back of the MFD.
in my case it was as simple as finding a MFD, and a cover and buying a few wires....and connecting it up. i cant say how easy that will be since you had the pop up display. im not sure if the cover is a direct fit.
let me know how you go
Just got one for my car, looks tops! However the Exhaust sensor and Inlet temps dont come up, any chance anyone knows how to get this working? I.E in the 6 item table that comes up they dont come up too only the first 4 or something.
Ok thats great, thank you David for getting back to me. Ray wouldnt be on the forums would he?
Yeah Ray from RE Customs is a SAU Member on here.
Or you can speak to barney (Brad) who also works for RE Customs- http://www.skylinesaustralia.com/forums/barney-m31951.html
I can't remember what Rays name on SAU is...
you have to run the diagnostic tool while the car is on, drive around for a bit and when it gets a reading for the exhaust it displays it on the mfd.
does that will all sensors
But with the wiring diagram ive got no chance it will pick up the sensor cause I dont have one lol. + I did not wire anything up for a exhaust temp nor did I bother with amb temp.
Edited by DECIM8
hey garland
thanks for that..
but at the top diagrams there is a seperate box for the triple combination metre which runs the boost and oil temp which i dont think mine has because my car didnt come with that option but instead with the standard sat nav and pop up screen. is there a way of sourcing out that part at all?
appreciate your help !
you can pick up every sensor in the gtt except Front Toqrue, Exhaust and inlet Temp.
for exhaust and inlet temp, youll have to call nissan and source a sensor. check here for the prices and part numbers
http://www.skylinesaustralia.com/forums/R3...t-t221016.html#
as for front toqrue, no chance cuz you have a rwd =[
thanks for that..
you can still do it....it just means you cant use the factory sensor line like me and andru had. which makes things tricky.
you can find out what every pin means by looking at this
as you can see PIN 33 is the "boost sensor.
all you need is a wire connecting that pin on the MFD to the right pin in your ecu. now me and andru jsut connected it to the triple gauge sensor which we all know is boost.
your problem is you dont have that, so somehow youll need to find which pin is the Boost pin in your ecu. only way to do that is to get a volt metre and test each indivisual pin to until you get the exact reading as your boost sensor.
:laugh:
Hey Garland, give Ray at R.E. Customs in Victoria a call, his guys installed my MFD and helped Andru with his, so im sure they will be able to help you out.
cheers,
David
hopefully ray can help cuz from what i remember, andru was the one who wired everything up, he only used RE Customs tools to do the job but did ask ray to soldier the wires to the ECU.
he did most of my car aswell.
a shame his not on the forums anymore, although he talked alot of shit he contributed to r34 owners alot. there are a few members on here who have done this so they would be your only hope from this point on.
:laugh:
  • 1 month later...
Ok so first of all the two points on the ecu namley pinout 47 and 60 that you would be refering to are actually different and would not work for the mfd or any gages for that matter (Sort of the same as reason the oil pressure and the water temp has to come from the main cluster, becase the ecu points are different.)
You would need to take it directly to the sensors. (pic attached)
Anyone wanting to fit one of these is quite welcome to ask me any questions as i have done this about 2 years ago. (with the help of Purpleline HKS forums) I also helped Andru when he first wanted to do this so im sure i can help anyone else out who wants it..
This is the site with the original diy that everyone copies. Good pics. My mates here helped me when i did this so more then happy to help you out any time.
http://www.hkskylineclub.com/new//forum_po...3160&KW=mfd
Few important notes for anyone undertaking this job:
Make sure the main power feed has a fuse,
Always disconnect the battery fully before touching the ECU,
Try not to use those cheap crimp fittings if you can help it but if ur soldering is not to good probley is a better way to go then trying to solder in a tight place,
Make sure you run the wires for the exhaust and intake from behind the dash and just lay under carpet on passenger side until you want to do it( these are both positive feeds so you should tape the ends off)
Good Luck hey.. :)
Edited by 99 GTT
  • 4 months later...
hi guys. i've done a bit of research on installing the MFD into my R34 gtt but i still have one problem... where can i buy one? i'd prefer the non nismo one (due to price) but i can't seem to source one very easily. any sudjestions?
thanx in advance :ninja:
Yahoo Auctions is your best bet.. and no they are not cheap, but cheaper then a new one from Nissan (around $4000) They also pop up here sometimes just got to keep your eyes out for them.. Garland (GMAN) had one fo a steal ($1000) a couple weeks ago and it just sat there for weeks.. Gone now of course...
Good luck.. :P
  • 4 weeks later...
Okay I am undergoing a bit of a makeover with my GTT, GTR nismo front bumper, GTR sideskirts, GTR rear bumper, GTR Nismo side and rear spats, GTR rear spoiler, GTR tailight covers, GTR rear fenders, GTR sills, full GTR interior, MFD and floor mats. All missing right now is the front wings and bonnet. Question on the MFD now, I got the MFD from a damaged GTR and want to power it up manually to make sure the screen is functioning. Will it be a simple process of just grounding and powering pins 1 and 2 on the and the ignition pins to get the display to show? Let me know as soon as so I can check it.
All you need to do is Positive feed to pins 1, 2, 3, 12 and a Negetive feed to 13 and 14.
Make sure you put a fuse on the positive feed incase you short it out..
Also as i posted above your best bet is to follow the original DIY by Purpleline from Hong Kong Skyline Club, as it worked for me over two years ago with his help.
But if you do need some help just PM me and i will give you a hand or answer any questions.
Edited by 99 GTT
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
