it should be 12v. But if you won't don't connect pin 3 and see if it boots. If not then connect it.
The accessory just turns the GTR badge on the screen, then full boot when ignition. but i am sure you need it to work.
Let me know hey.
  • Replies 97
Posted Images
Okay I think I have found the problem, seems like removing the cracked laminate from the front of the screen made the screen show totally white. I have ordered a polarized laminate film to replaced the cracked film I had before hopefully it helps the visibility problem I am having. I found a similar problem on gtr.co.uk,
http://www.gtr.co.uk/forum/100609-mfd-lcd.html
One question I have I am seeing the diagnostic mode sequence on the manual and it shows all 15 sensors that can be monitored, I would really like the oil pressure signal. Has this ever been done or is it on certain model MFDs that this can be accessed? I have a V-Spec MFD BTW and here is the pic in question.
I've just been installing the MFD as of last night - and have a bit of a question:
So far I've only installed the power/acc/ign, 3 gauge cluster wires (illumination/oil temperature/boost) & dash wires (water/oil pressure) - next up is the wires from the ECU (speed, injector duty, revs, throttle position) -- but on doing a test power-up to make sure everything is fine, only water temp seems to be showing up. I've tried running the diags to test sensors, and even then whilst it seems to detect sensors, nothing is really coming up besides water temp - boost just sits at 0. I've checked, double-checked, and triple checked the conncetions. Does anyone know if this is normal?
I'm wondering if maybe it's needing the inj/speed/throttle sensors from the ECU before it'll initialise the other sensors properly? I'm hoping that's the case anyway. Ah well, I guess I'll put in the remainder of the ECU wiring and see what happens. Otherwise, I'll be trying to track down whether it's a grounding problem or something else weird.
Fingers crossed this unit isnt a dud (it came from a working car) - I can't imagine how much it would cost to repair :P
Well - that solves that - and is a warning / informational thing for anyone else wiring one of these up - your sensors, etc won't display properly until the ECU sensors are all hooked up too (injector/throttle/speed/rpm).
MFD is now working beautifully :(
If you follow the wiring diagram that Purpleline made. The one i put the link to then your oil pressure sensor will be detected. But the only way to have it on the display is to buy the Nismo upgrade at about $900 to $1400 and this will then give you upgraded Boost to 2BAR and replace throttle position with Oil pressure.
Also adds the G meter lap time and data logger etc. (these only work in GTR)
Check it out here.
Nismo Link
:D:P
Edited by 99 GTT
  • 3 weeks later...
Does anyone have the wiring for the Intake and EXT sensors for the MFD. I have the Intake sensor and the EXT on order and as I have the Vspec model I have access to them. Just need to have both wired to have them functionable on the MFD unit. Thanks and also got my MFD working proper so weekend it is going in and also going to have the wires for the EXT and Intake run as well.
Jason.
  • 1 month later...
Why do you say it will only work in a GTR?
The lap timer is only a switch button to add, data logger comes with the kit.
The thing I would like to know is the G meter working in a GTT with the nismo kit?
Anyway thanks for the post it helped me when I was stuck with the yellow error message (it was because I haven't wired the ACC +. The screen displays exactly the same message when the ignition is not on and when you press a button)
it wasnt easy, we were a bit confused when we 1st wired it up and got this error message.
we still dont know wat it means but we gave every input a extra shove
and...... it worked =D
  • 5 months later...
A question for those who have done it - how has anyone hooked up the GTR intake sensor on the GTR?
It doesn't use a bung as in the exhaust temperature sensor, it screws in - which leaves me wondering how you would mount this up, and especially in such a way that it seals it up against pressure leaks, etc.
Very interested to hear back from those who have done it ....
  • 1 month later...
MFD is now working beautifully :)
Lol I just freaked out tonight, thinking my MFD unit is stuffed, when my boost stays at 0, but it made me feel better after reading what you said, so now I'll wire up the ECU tomorrow and see how that goes :)
Hey guys, I've just hooked up my MFD, but I have a question, how come it only picked up the first 4 sensors? Boost, throttle, oil temp and water temp? It doesn't say it picked up the other sensors, but I know my rev light works. Because isn't there like 15 sensors all up? Including some GTR ones (I know I won't get int and ext temp), but others. Cheers!
  • 1 year later...
Alright, finally done.
It took me a couple of days per my battery dying and a couple blown fuses. I received a lot of help from a dude named Dan on GTROC:
http://www.gtr.co.uk/forum/123413-r34-mfd-into-r33.html
and a dude named Bala from Malaysia:
http://nissanskylineer34.blogspot.com/2010_07_01_archive.html
I didn't want the whole install to be very messy so I bought some items from a local electronics store and a Radio Shack.
GTR harness (MFD unit and cover) from: http://www.jdmautolink.com/
<img>https://lh4.googleusercontent.com/-ujmAZPSSJC0/TvjqKnYdyrI/AAAAAAAACUA/TPiG63sfBHs/s640/SS851775.JPG</img>
GTR harness after I removed the wires I needed:
<img>https://lh6.googleusercontent.com/-3tod8uE0GDs/TvjqINp5BqI/AAAAAAAACT4/63hwSXVo-Nk/s640/SS851780.JPG</img>
Electrical bits - 18g wire (green, red, black), harness plugs, crimper, taps, etc:
<img>https://lh5.googleusercontent.com/-kCaP1DHOQ1I/TvjqILPg-iI/AAAAAAAACTs/GBEfe1mK-pQ/s640/SS851786.JPG</img>
I plugged the wires into 4 (male/female) harness endings after I tested the MFD.
<img>https://lh5.googleusercontent.com/-nyHEThVwcvw/TvjqKziRcoI/AAAAAAAACUE/E-OcKsiibZQ/s640/SS851779.JPG</img>
New harness made with wires labelled for future reference:
<img>https://lh5.googleusercontent.com/-iGPunSk6kao/TvjqIPAEUyI/AAAAAAAACTo/4uQ3-pmw3UY/s640/SS851787.JPG</img>
I don't have a picture of the functioning MFD but you get the idea. I tapped into the wires that the MFD needed to function properly and labelled them as well.
A few sensors still aren't working. For example, my MFD isn't reading INJECTOR but my Apex AVC-R is. Ironically, they're both plugged into the SAME ECU wire. I'll assess that some other weekend.
What sort of a stupid comment is that :rolleyes:
I know for my own MFD install it was a case of either:
i) find an electronic device that displayed multiple gauges. A few options here none of them particularly cheap. Still left with triple gauge cluster - what's the point?
ii) Replace triple gauges, install additional gauges to try and get a good idea of what's going on
iii) Simply just install an MFD - a device which hooks up perfectly, doesnt cost the earth, isn't defectable and displays multiple gauges without any dramas.
Seems like a pretty obvious choice to me. Feel free to explain why you feel so strongly about this view.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
