  • Replies 97
Posted Images
Yo, man. My GTT is basically a RWD GTR.
600rwhp with a RB26DETT transformed to a RB27DET and a GTR tranny mounted underneath.
I NEEDED the MFD to monitor my car's vitals signs so I can help avoid trips to the Skyline doctor.
  • 1 year later...
Lol he be mad because he's only got a 32 and this swap won't work for him.
so... I have a R31 and I am about to go full custom with one of these.
question as well. I see a tach input on this - can I get a TACH gauge up on this unit at all?
I have pulled the tach out of my dash to put this display in place.
(and 2yr thread bump ~ !~)
Lol actually thinking of putting one in my ralliart colt, but so many better aftermarket options out there.
Oh good to see u still around chris.
yep still around , still screwing with old nissans..
Chris, There is no way to show RPM on the unit itself. The RPM input is used to trigger (at a desired point) the REV shift light on the unit. Let me know if you have any questions as I have just finished installing one of these (properly) into my GTT.
got this one on the bench and went looking. looks like I lost the tach in my car. its auto and no biggie.
progess shots: (reverse engineering the switches and video display at that point.)
1098176_10201795206065101_1210220218_n.j
anyone have an exact translation of the G sensor pinouts. I have the HK PDF but the pinuts for brown 25.26.28.29.38.39.40.44 are VERY vague as to function.
Chris, see attached image file. I copied this right from the Nissan R34 GTR Supplemental Manual. It has all the trouble shooting stuff and pinout for the MFD. Maybe it makes more sense than the HK translated one to you.
  • 8 months later...
Hi everyone,
I' settling the nismo upgrade on my GTT's MFD.
Does someone know how to install the exhaust sensor?
I mean like a tutorial of the set up?
Do I need to drill a hole or buying a v-spec pipe for example?
Thanks for the reply,
Oh if it could help, I have the Japanese manual and if needed I can take some picture of the two different board side to side while I will install it.
Really it wouldn't be worth it to go and find a V-Spec pipe to install the sensor, and it's not like it would just fit if you did get one.
1. Drill hole pre-cat but away from turbo dump (i installed mine 2cm before cat).
2. Weld bung in to accommodate sensor.
3. Screw sensor in and run wiring up through floor grommet under passenger seat.
4. Terminate 1 sensor wire to eyelet and bolt/screw to floor pan under seat.
5. Extend other sensor wire (it doesn't matter which), to the MFD display neatly and connect to exh. temp. sensor pin.
Don't forget to reinitialize the unit after start up to detect the sensor (and inter-cooler sensor if your installing that too). Although i guess you have to do that anyway since your installing the Nismo board.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
