Guest INASNT
Originally posted by JET-33
ey i just got home
i dont get owned by any1...u call it a fkn computer, that controls friggin hicas, get real, then its a fuel pump..cant u tell the fkn difference....:D
maybe u need to get some mods so u dont have to pretend ya "computer" in the boot is a little fulsic bov areh haha
haha the hicas computer is a computer as it control the rear end steering just like the 'computer' in your kick panel controls everything else!!!!!
do u even know what mods ur car has??? :)
So what do you think controls HICAS?
you brain ?? :bahaha: :bahaha: :D:(
:Owned:
You wouldn't know the difference as you definately dunno what a HICAS ECU is... or that it exists.
And you probably dunno WTF a fuel pump is to begin with.
computer in the boot???
what u smokin man?
hahahhaha :D , couldnt resist :D
you brain ??
:bahaha: :bahaha:
HAHAHAHHAHA , lets not get nasty with things :( i think jet became a little confused when the term computer was used , but i posted the meaning up so there are no problems anymore :)
hey akeenan, where abouts did u find the bolts in the back? coz i've taken out the rear seats already and couldn't find anything loose there. been driving around for about a month without the seats & also wondered what the shhh noise was hehe. anyways, im certain theres a bolt sliding round the back, sounds horrible wen i take corners. just can't find the bastard!
finally found the source of the clunking noise! if anyone else has noises from rear, take out the jack and reach into that section until u can touch the bottom. i found a 10cm long rusted piece of rod. dunno wtf it is. pretty hard to get to, could barely fit my arm down there and just about got it stuck too lol.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
