Guest INASNT
Originally posted by JET-33
ey i just got home
i dont get owned by any1...u call it a fkn computer, that controls friggin hicas, get real, then its a fuel pump..cant u tell the fkn difference....:D
maybe u need to get some mods so u dont have to pretend ya "computer" in the boot is a little fulsic bov areh haha
haha the hicas computer is a computer as it control the rear end steering just like the 'computer' in your kick panel controls everything else!!!!!
do u even know what mods ur car has??? :)
So what do you think controls HICAS?
you brain ?? :bahaha: :bahaha: :D:(
:Owned:
You wouldn't know the difference as you definately dunno what a HICAS ECU is... or that it exists.
And you probably dunno WTF a fuel pump is to begin with.
computer in the boot???
what u smokin man?
hahahhaha :D , couldnt resist :D
you brain ??
:bahaha: :bahaha:
HAHAHAHHAHA , lets not get nasty with things :( i think jet became a little confused when the term computer was used , but i posted the meaning up so there are no problems anymore :)
hey akeenan, where abouts did u find the bolts in the back? coz i've taken out the rear seats already and couldn't find anything loose there. been driving around for about a month without the seats & also wondered what the shhh noise was hehe. anyways, im certain theres a bolt sliding round the back, sounds horrible wen i take corners. just can't find the bastard!
finally found the source of the clunking noise! if anyone else has noises from rear, take out the jack and reach into that section until u can touch the bottom. i found a 10cm long rusted piece of rod. dunno wtf it is. pretty hard to get to, could barely fit my arm down there and just about got it stuck too lol.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
