June '08 Group Buy for Ruzic Engineering ATESSA Controllers
If you own a GTR, GTS4 Or Stagea, these are a must have!!
These units are locally made & from all reports are the equal or better that any ATESSA controller available anywhere.
There are currently 4 in stock & ready for immediate delivery, any colour you want as long as it's black but subsequent units can be supplied in just about any colour on a case-by-case basis (extended turn-around times & added cost will apply for custom colours, PM for more info). All cases are anodised alloy, not painted or plastic so they they won't peel, fade or otherwise deteriorate over time. Units for this Group Buy will be manufactured on-demand & delivery date will be confirmed at time of order.
Price is $499 + Del & will send anywhere in the world.
Tracking & Insurance is highly recommended. Just like with car insurance, you don't need it 'til you need it........
Special Offer: For the FIRST R34 GTR & FIRST Stagea owner to purchase a Ruzic Engineering ATESSA Controller there will be a $50 "cash-back*" making the price $449 + Del. This is a ONE-OFF so first in first served :D
Pics to come.....
Ruzic Engineering GTR 4WD Torque Split Controller
Designed and Optimised for Circuit Racing
The Nissan Skyline GTR has the ability to proportion drive torque to the front wheels at a continuously variable rate. The on board 4WD computer determines the torque split based on sensor inputs. The maximum torque to the front wheels can be up to 50%.
The 4WD Controller has been designed to alter the lateral G Force signal read by the 4WD computer. This in turn allows the device to alter the way the torque split is applied to the front wheels. It will apply the front wheel drive earlier, or later, depending on the setup.
The device has five different ‘maps’ (each with 32 individual set points for fine tuning) that can be used to alter the front torque split. These range from a simple line, to curves that allow the car to run as factory during low G Force curves, but apply more front torque for higher G Force curves.
By using an external toggle switch it makes it possible to setup two different handling strategies and transfer between them instantly. This feature allows the driver to optimize handling for different corner types at the race track. It is possible to have one setup for high speed corners and a different setup for off camber switchbacks.
With the device connected to the lateral G, longitudinal G and 4WD percentage signals, the user can perform handling analysis and determine how each map and scale factor setting is affecting the traction circle and grip of each turn at the track.
Data logging can be performed by using a memory option. The device will log to a laptop, or external memory. The data logging can log values at rates up to 20 samples per second.
Features:
- Input Signals
- Lateral G Force
- Longitudinal G Force
- Front Torque Split Percentage
- Toggle Switch to Select Between Setups
- Output Signals
Modified Lateral G Force signal
- Serial Port / Data Logging
Data logging of sensor inputs settable up to 20 samples / sec (requires external memory)
- External Software
Desktop / Laptop software to configure device remotely
Driver Experiences:
- Simon a.k.a. 'Si’
"The Ruzic Engineering 4WD Controller certainly made a huge difference to getting the power down. Plant the accelerator and hang on as you do massive AWD power slides. Started off with it set to just a bit above factory torque and found it was still very tail happy, so upped it a fair way and the difference was awesome!"
- Michael a.k.a ‘Jetman’
"I have had the Ruzic Engineering 4WD Controller and Thermo Controller in my car for some time now and have not been able to fault them. My GT-R is my transport to work, where it sits in the sun all day and also shows up to the occasional Track Day. The Controllers are compact and robust enough to fit anywhere you want them to in the cabin. I have one mounted above the center gauges and the other in the center console. They are easy to read at night when I’m traveling home from work at 02:00 and don't distract you from the road.
The testing that I have done has mainly been at Track Days where I started using Map 1 with a zero scale factor. My car would be extremely susceptible to over steer on most corners. Switching then to Map 3 using the toggle switch, with 80 percent scale factor, I would be able to apply acceleration earlier out of the corner and not have any problems with over steer, just a nice 4wd power slide. Glancing quickly mid corner at the torque indicator, I do remember seeing the needle moving up around the 30 to 50 position at times. The indication lines are close together if you know what I mean. Hard to pinpoint accurately the amount of torque to the front wheels. I am waiting for a Data Logger Cable to arrive to plug into my PDA, so I can log everything it is reading.
Now my car set up is not the greatest for any Track at this stage by my standards, it is good on the road, but on a track, (different kettle of fish), so to make my tail happy car very close to neutral, and giving me better control on fast and slow corners, is fantastic.
I know many hours have been spent on this project, probably nearly adding up to two years R & D trying to make a product that is user friendly, extremely accurate, sturdy yet robust with an easy to read large backlit LCD display, and dam well perfect.
This 4WD Controller is fantastic and a blessing for anyone out there that is having problems with over/ under steering on a GT-R, GTS-4 and/ or anyone who just wants to fine tune there ride for road or track."
- Peter a.k.a. 'Maccattack'
"Some of you may have read about Paul Ruzic building and (now selling) 4WD Controllers for GTR's. I purchased a unit from Paul and was "testing" it in the car on yesterdays Time Attack day at QR. I thought I would provide some feedback for anyone pondering a purchase.
May I first start by saying that I drive my car fairly hard on track days but by no means would I consider myself a fantastic driver. In honesty, I have trouble being able to really tell the difference between various sway bar and suspension settings, tyre pressures etc. I tend to check the tyres before I go out and then drive it like I stole it. My Kahunas aren't big enough to take corner one at the speed I think it should be taken at.
The 4WD Controller allows you to store and use (through a toggle switch) 2 separate "maps". These maps are variations on the way the car normally responds to the signals coming from the G sensor. Because you have so much variation, it is somewhat overwhelming as to what maps to use.
I started with an aggressive 4WD map (map 1) and a map which is slightly more aggressive than the way the car reacts as normal (map 2). I perhaps wasn't using the toggle switch as much as I should because once I had started driving the car with the system using map 1, I got so used to it, and liked it, so much that I didn't want to play with the toggle.
The car still switched between 2 wheel and 4 wheel mode, but it switches to 4WD so early and seamlessly that you don't even feel the transfer. Corners, both low and high speed, became (for me) much more controllable. I used to come onto the straight in 3rd gear feathering the throttle to maintain boost, basically steering with the back wheels. Now you can come onto the straight in a full 4 wheel power slide and you can "feel" exactly what the car is doing. As it turned out I shaved a second off my times for the Clubman and National Circuits. Admittedly I changed back to a tyre I preferred, but I am sure I can keep the times coming down.
As an overview, so far as the controller goes - I'm wrapped. I still have a fair bit of mucking around to do to really get to know it but the level of 4WD control is awesome. Whilst I can't drift my car, I can pull off some awesome power slides at the moment. If you are looking at a 4WD Controller for your car, DEFINITELY consider the Ruzic Engineering unit. You are more than welcome to check out the quality of the unit in my car."
- Ed a.k.a ‘EdGTR’
"Just a quick run down of my experience with the Torque Split Controller. I own a R32 GTR that is quite standard it only has an Apexi Power FC, adjustable camber and castor arms and a cat back and of course the TSC (Torque Split Controller). I took my car down to Wakefield for the Australia day track day with the auto sports guys and had a great time. I only just got my car ready for the day because i had a minor front ender in it a week before Christmas and it took a while to get all the parts sorted, but we got there even with a left hand front shock that by half day had leaked all its oil out and really had a lot of trouble keeping the wheel on the ground. The shocks and springs all look original so they have done ok being 17 years old, they will be changed very soon.
OK so to the TSC because that’s what you will be here to read about. First session out I took it easy after getting the Power FC tuned and a totally different wheel alignment done a couple of days earlier. But i found that the car really wanted to slide out of corners. The rear diff is also getting quite worn which was letting the inside rear wheel spin which really didn’t help with getting the power down. About halfway through the first session (4 to 5 laps) I didn’t like how it felt and wasn’t getting the power down all that well so i changed the TSC from standard (map 1 no gain) to map 2 and 10% gain and the difference was huge! Being able the get on the gas earlier and a lot harder it really changed to feel of the car. It felt and was a lot faster through the tighter corners where before I really had to pedal it, now I could just accelerate out of the corner. Through changing the drive to the front it held a tighter line by feeding the power to the front earlier and also helped with mid corner turn in.
I left it at this setting and thought that I needed to learn the track and get my lines a bit sorted. Later on in the day I started playing with the gain looking for the best exit out of the last corner onto the straight. I didn’t get a chance to play with the other maps but found that just on map 2 I was able to tune everything from power on under steer due to the front wheels breaking traction to nice smooth neutral over steer just by adjusting the gain. The biggest thing I found was that it made the car a lot easier to drive faster on the track. I’ll be heading to eastern creek in a couple of months with coil-overs and am really looking forward to seeing what it can do around corner 1.
- Ben a.k.a. 'BenR32'
This is yet another testimonial to the great gadget that is Paul’s GTR torque controller. I have had mine in my car for about 4 months, and I can honestly say that it has been the biggest handling upgrade I could have made. It is particularly useful in setting up the car for the conditions on the day, with a recent wet track day demonstrating it nicely. I was able to dial up sufficient RWD to get some oversteer into the corner, then at the apex when the g-forces really started kicking in there was enough FWD to pull the nose out of the corner and set it up nicely for the next one. Result? Controlled 4 wheel drift with the nose pointing the right way. And this was by no means working at the limit of the controller.
Its nice to be able to see the amount of drive going to the wheels in a real time digital display, as it means that you can dial the drive FW or RW to change the angle you reach at apex, and get the neatest and therefore fastest corner your car can handle.
I tend to be a minimalist in my cars interior, and although I know lots of people like to mount their controlled above the central air vents, I have mounted mine just left of the wheel on top of the digital clock. Sits there nicely, easily accessible for me and I don’t have to shift my eyes too much to see what its doing. All in all, if you haven’t already improved your GTR with one of these, you should. See you at track day!
No pictures? no probs here's the link to the original thread
http://www.skylinesaustralia.com/forums/Gt....html&st=40
Get in at this price guys, I love mine and I paid $150 more than this group buy.
Do I get $50 off my next purchase for the sales pitch?
  • 3 weeks later...
For what it is worth I mounted mine in the boot. Hung it off the ATTESSA computer.
Reasons being three fold:
1. It is out the way so no one sees it/fiddles with it.
2. The wires you need to splice in are all available from the ATTESSA unit itself making the installation easy.
3. No need to hack about the interior or remove the instrument panel.
Man I love playing with it, and since the ashtray was never used in mine, it's a great replacement.
Ohh shii not more toys!!
i'm going to consider this how long is this offer on for?
Cheers
Andrew
A new batch is going into production as we speak & should be available in a few wks. Get your orders in!!
  • 3 weeks later...
is this group buy still available? has the $50 discount been used by a R34 owner yet?
I am interested. Could someone email me at trevor at t24ever dot com ??
Hey Trevor, e-mail on the way.
For everyone else, the first new batch should be finished this time next wk. Get your payments in, first in first served.
PM me for details :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
